Am I Missing Under Body Armor?
Discussion in '5th Gen 4Runners (2010-2024)' started by dxhum, Nov 26, 2022.
  1. Nov 26, 2022 at 2:26 PM
    dxhum
    dxhum [OP] New Member
    About 3 weeks ago, I took my 2020 4Runner Off Road Premium to the dealership to get its 30k service. During that time, they informed me that I needed breaks; $400 for the fronts and $400 for the rears. I opted not to get the break work done because $800 for breaks is overpriced.
    Today, I went to my honest, reliable and competent mechanic to have the break pads replaced. When we picked up the vehicle on the lift, he pointed out that my under body armor was missing!
    Here are the pictures...
    The dealership is telling me that there was never under body armor. I purchased the Off Road Premium BECAUSE it offered under body armor in addition to other features. They looked under a 2022 4Runner Limited as said "it looks the same".
    I responded by saying "you can't compare a 2022 that wasn't designed for off road with a 2020 that was."
    So my question: Does the 2020 4Runner ORP come with under body armor? If so, then the only thing I can think of is that someone was going for the Cat-Converter and got spooked off before they finished the job, or the dealer didn't put it back on.
    I know insurance companies can tell how a vehicle is equipped based on the VIN. Would that work here?
  2. Nov 26, 2022 at 2:33 PM
    Kezin
    Kezin New Member I guess?
    ‘21 and ‘17 Limiteds
    All trims have the same skid package unless you get the pro with the pro skid so what the dealership did by looking under a Limited is valid. Looks like you’re missing the little plastic tail on the second skid though. Not really “protection” so I wouldn’t fret
    Singleminded and dxhum[OP] like this.
  3. Nov 26, 2022 at 2:40 PM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    I believe your 20 ORP is like my 18 ORP, with 3 pieces of “armor”. Actually more like underbody covers. A plastic cover in front just under the radiator, a metal one further back that covers the oil filter area, and another metal cover behind that with the small door covering the oil drain plug. Those two tabs that stick out of it have nothing connected to them.
  4. Nov 26, 2022 at 3:00 PM
    Unless you had added aftermarket skids, there is no 'armor' that you're missing. You have what comes from the factory. If the sales person told you the off road comes with any armor, they were deceiving you. Your honest, reliable and competent mechanic doesn't appear to know all that much about 4Rs.
  5. Nov 26, 2022 at 3:03 PM
    lrizzo
    lrizzo New Member
    Northern New Jersey
    Nope I thought I was missing one when I got my 2021 brand new. I did the service myself and thought something was missing because of those 2 tabs hanging off the transmission skid plate. Went to the dealer and looked at another Venture like mine and it was the same.
    Singleminded likes this.
  6. Nov 26, 2022 at 3:44 PM
    Commited
    Commited New Member
    Oscar
    So Cal
    2019 Silver Metallic TRD ORP
    Tinted fronts, blacked out overlays.
    Wait $800 for a break job? Wow.
  7. Nov 26, 2022 at 4:02 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    Did you run over imitation crab?
  8. Nov 26, 2022 at 4:19 PM
    Worse yet, a brake job at 30,000 miles?????? Why? Is this a taxi in NYC?
    There is no missing armor by the way. Even though most forum members here dont consider the two stamped metal factory skid plates as proper armor, anyone else could reasonably refer to it as armor. And to be fair, most people except us here on the forum, would stop, back up, and try another line if we heard the underbody touch down on something. They are decent if used in this way, as long as you dont go bashing around looking for trouble.
    But if you need armor to continue pushing through things you’ve hit, then these shouldnt be considered armor.
    The tabs on the rear most skidplate are for some sort if additional shield that comes on the Limited trim (plastic shield I think).
    The green capped turn screw on the oil drain plate is a little janky though ;)
  9. Nov 26, 2022 at 5:16 PM
    Daddykool
    This^^^ I replaced the rear pads on my 2019 at 100k miles. The fronts still had 50k left in them, going by pad thickness. So 30k miles sounds ridiculous.
    (And yes, it seems that rear brakes wear more quickly than front in some cases/vehicles. Never used to be the case.)
  10. Nov 26, 2022 at 5:28 PM
    Tama1968
    Tama1968 New Member
    Florida
    I'm at 65k miles on my 2019 and my brakes still look good...just guestimating but probably another 5-6k miles left. and won't be anywhere near 800 bucks
  11. Nov 26, 2022 at 5:29 PM
    dxhum
    Show me an expert that knows all about every car they touch, and I'll show you a liar. And this is more about product knowledge.
    Okay... so maybe "armor" isn't the correct word. Lets call it "shielding". I didn't mean to imply that I expected to see the kind of armor one might find on a rock crawler. But my truck had shielding under it that was in 3 pieces: The first is plastic in front of the front wheels. The second is metal that covered the oil drain plug and then the third piece which is apparently not there.
  12. Nov 26, 2022 at 6:16 PM
    Joe68RS
    Joe68RS New Member
    Joe
    Louisville, KY
    2023 Lunar Rock ORP
    You have all 3. The third piece is the one that has the two tabs sticking out the back and has the access panel for the oil drain. The second one is shorter and covers the oil filter location - see blue outline below. The is no factory option option that covers the catalytic converters and transmission pan.
    dxhum[QUOTED][OP] and Saker like this.
  13. Nov 26, 2022 at 7:53 PM
    I’m curious what your mechanic thought about the brakes. Were they worn that badly already?
    Singleminded and Saker like this.
  14. Nov 27, 2022 at 3:56 AM
    Matt83
    Matt83 New Member
    Northeast
    You have everything on the truck that came from the factory. There is nothing that attaches to the two tabs on the rear of the third panel.
    Slopemaster likes this.
  15. Nov 27, 2022 at 5:08 AM
    dxhum
    Yeah... thats $200 per tire! I said "no thank you".
    Tama1968[QUOTED] likes this.
  16. Nov 27, 2022 at 5:09 AM
    dxhum
    Yes... I wondered the same thing. But the dealership was being honest; the rears were at 3mm and the fronts at 7mm. I did them all.
  17. Nov 27, 2022 at 5:14 AM
    dxhum
    3mm in the back and 7mm in the front.
    Yes, I was surprised as the truck only has 27k.
    I always knew that the front breaks wear more quickly because of weight transfer to the front of the vehicle when breaking. But it was explained to me that with the advanced breaking features on newer cars, this isn't necessarily true.
    Slopemaster and Daddykool like this.
  18. Nov 27, 2022 at 6:02 AM
    doc4216
    doc4216 New Member
    Shannon
    The Land of Cle
    2015 SR5 Premium
    Dasaíta HU, Bilstein 5100s, AT Tires, Coveted grill lights
    As stated, you have all three pieces, so that’s the good news. I am surprised at how quickly you need to replace them.
    Also, brakes not breaks.
    Pentangler, 2Toys, brownersd and 4 others like this.
  19. Nov 27, 2022 at 6:13 AM
    dxhum
    I know this... what's wrong with me? :(
    Anyway, regarding the BRAKES, it was explained to me that new cars with traction control and anti-lock brakes will "sit" when applying the brakes. This leads to a more even wear of the brakes.
    Daddykool and doc4216[QUOTED] like this.
  20. Nov 27, 2022 at 6:24 AM
    Chris In Milwaukee
    Chris In Milwaukee New Member
    Chris
    I was just in for my 50K checkup last week and they said my brakes were showing wear as well. I'd have to pull out the sheet to see by how much. But they're not at the limit of anything AFAIK.
    As for the $800, I'd say it's fair (to me). Parts and labor today are what they are. $100/hr if it's a dollar, and all the pieces that go with it. If you want it done on the cheap, you'll have to learn how to use some tools, in my opinion. If I were to do brakes, it would take me all day. If I charged myself the same rate, it would cost me a lot more. :)
    For me, when it's time for brakes, I'm going to spend that day and upgrade my vehicle to a big brake kit. Which is way more than $800!
    For a point of comparison, my Ram truck brakes were $1200.
    dxhum[OP] and McSpazatron like this.
  21. Nov 27, 2022 at 6:48 AM
    doc4216
    doc4216 New Member
    Shannon
    The Land of Cle
    2015 SR5 Premium
    I figured as much. I changed mine around 80k (I think). Not sure if they were replaced early as I bought it with 49k already on it (it was a lease in its former life).
    I thought the same thing until I started looking into it. I watched some YouTube, read the repair manual, and had a basic mechanical knowledge. It went pretty smooth but it did take me about 3.5 -4hrs.
    I also thought about upgrading to a better brake kit but I may invest more into a smoother ride instead.
  22. Nov 27, 2022 at 6:53 AM
    Matt83
    Matt83 New Member
    Northeast
    Is this for pads only? $800
  23. Nov 27, 2022 at 7:06 AM
    2020 4Runner
    2020 4Runner New Member
    Fl
    I would yank all of that crap off and install a full set of CBI skids. Solid product and helps with cat protection from theft.
    dxhum[OP] likes this.
  24. Nov 27, 2022 at 7:30 AM
    Chris In Milwaukee
    Chris
    It’s only money :spending:
    Ironguy likes this.
  25. Nov 27, 2022 at 9:14 AM
    Glenn Goodlett
    Glenn Goodlett New Member
    Glenn
    2020 TRD Pro
    Paid for
    I'm at 70K and my brakes look to be at 50%.
    Tama1968 and Daddykool like this.
  26. Nov 27, 2022 at 9:45 AM
    Whoa, whoa, whoa! I thought we had to choose 2 of these 3. Where did you find such a person? :D
  27. Nov 27, 2022 at 11:42 AM
    2020 4Runner
    Fl
    They are expensive. They were the best that I found for full skids and added cat protection.
  28. Nov 27, 2022 at 5:27 PM
    dxhum
    Noooo... parts & labor.
  29. Nov 27, 2022 at 6:11 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    @dxhum
    Inquiring minds want to know...
    alittleoff likes this.
  30. Nov 27, 2022 at 6:58 PM
    dxhum
    Not sure what this means...
