Alpharex LUXX headlight issue
Discussion in 'Lighting' started by AlaskaLunarT4R, Aug 17, 2022.
  1. Aug 17, 2022 at 12:39 PM
    AlaskaLunarT4R
    AlaskaLunarT4R [OP] 2022 Lunar Rock OR
    Anchorage, Alaska
    Hey guys,
    I am new to posting on the forum, but have been around for quite some time.
    I am having an issue with my LUXX Alpharex headlights on my 2022 OR... The headlights came with the converters
    https://www.alpharexusa.com/product/21-toyota-4runner-headlights-converters/
    and when I plugged them in, my high beams don't work. The DRL harness is all plugged in and wired and I tapped into the 10A INJ fuse, exactly as the instructions say. Everything else works as its supposed to, just not the high beams. I was wondering if anyone had some insight on exactly where to plug in the converters? I appreciate any guidance with this!!
    I have emailed Alpharex asking for some guidance but they sent me the same .pdf file I was already looking at, instructions up to the 2020 models.
  2. Dec 9, 2023 at 3:14 PM
    derelique
    derelique New Member
    22 4Runner Trd Pro
    Did you figure this one out? I’m having the same issue on lights I installed today.
  3. Dec 9, 2023 at 10:17 PM
    kojak
    kojak New Member
    21 SR5P 4x4
    I don't have Alpharex, but the harnesses that came with my headlights were pinned wrong for my '21.
  4. Dec 9, 2023 at 11:16 PM
    I wouldn't tap into my fuel injection circuit to run a headlight function, just saying...
    backpacker likes this.
  5. Dec 11, 2023 at 7:41 AM
    derelique
    22 4Runner Trd Pro
    I was confused since the beginning of this install. The website showed 3 headlights running and the 4th one was the high beams. I guess the version I got has 4 low beams. My trim and year had the stock DRL plug only and I thought it was also the high beam. For my model I used both those plugs on the adapter as the low beams and high beams were in the same projector. I thought I tested both ways and it wasn’t working. Possibly with things unplugged I missed something. Either way, mine is working as it should now.
