Alignment specs
Discussion in '5th Gen 4Runners (2010-2024)' started by duc_minh206, Jun 8, 2023.
  1. Jun 8, 2023 at 3:33 PM
    duc_minh206
    duc_minh206 [OP] New Member
    2020 4runner OR
    Good afternoon y’all!
    I just did alignment for the first time since the 4Runner lifted. I’d like to ask if the rear toes specs looks normal. If not, how can I adjust the rear so the toes specs from both side won’t be too much different. Thanks!
  2. Jun 8, 2023 at 3:47 PM
    Not sure what you are expecting.
    Its in specs if thats what you want.
  3. Jun 8, 2023 at 3:54 PM
    duc_minh206
    2020 4runner OR
    It looks like the left side is toed out while the right side is toed in. The difference from both side of the rear just too much different compared to the front so I'm curious If something broken such as rear axel bent....
  4. Jun 8, 2023 at 4:02 PM
    Well my bad I didn't read rear.
  5. Jun 8, 2023 at 5:03 PM
    duc_minh206
    2020 4runner OR
    Lol no worries. We technically only need to focus the front alignment specs. I didn’t notice about the rear spec after getting home.
  6. Jun 8, 2023 at 7:00 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Alignment March 2023, I have 3" after market shock and spring lift
    Toy4X4 and duc_minh206[OP] like this.
  7. Jun 8, 2023 at 7:08 PM
    duc_minh206
    2020 4runner OR
    All your specs looking really good. I'm still doing research how to bring everything back to better specs. Many reasons I have in mind. It could be the wheel offset, the panhard bar not center, rear camber, worst scenario is bent rear axle. Mainly to bring the thurst angle close to 0 as much as possible.
  8. Jun 8, 2023 at 7:45 PM
    JETSPD1477
    JETSPD1477 New
    Typical 4Runner
    a bent rear axle is unlikely. it would take a catastrophic event to destroy a solid axle or the shafts in any measurable way. it’s something you’d definitely know happened.
    toe and camber are independent of each other and are 1:1 vs each side. nothing real complicated and is why there are no specifications for the rear.
    how much is the rear lifted? adjustable panhard or trailing arms? info about your set up can be helpful.
    djwantke likes this.
  9. Jun 8, 2023 at 8:16 PM
    Thanks man reassuring to hear, no offence to you. If it helps to know, my wheel offset is 0, backspace is 5, added 1.25" Spidertrax wheel spacers a little while before this alignment, and had a successful alignment 1.5 years before running them (following the suspension lift and 33's and UCA's).
  10. Jun 8, 2023 at 8:34 PM
    JETSPD1477
    JETSPD1477 New
    Typical 4Runner
    spacers and wheel offset don’t affect alignment angles. the angle of the wheel changes when the angle of the hub changes.
    duc_minh206[OP] likes this.
  11. Jun 8, 2023 at 8:43 PM
    duc_minh206
    2020 4runner OR
    That's my question too. I'll check with them tomorrow about the rear specification. I have 2" rear lifted.
  12. Jun 8, 2023 at 8:45 PM
    duc_minh206
    2020 4runner OR
    Mine has -12 offset with 4.3 backspace.
  13. Jun 8, 2023 at 8:47 PM
    duc_minh206
    2020 4runner OR
    Indication of broken hub do you think?
  14. Jun 8, 2023 at 9:04 PM
    JETSPD1477
    JETSPD1477 New
    Typical 4Runner
    a failing hub and it’s bearings will let you know it’s dying. it’s something you would hear and feel. if you’re wondering if maybe a hub is bent somehow then the wheels would wobble when they roll.
    the toe and thrust ion your sn’t severe. if you’re that anxious about how the axle is located i’d start by correcting the panhard.
  15. Jun 8, 2023 at 9:13 PM
    duc_minh206
    2020 4runner OR
    Ya, If it keeps sitting like this, sooner or later the bearing gonna give out. Even though everything still in acceptable range specs (except thrust angle), It's still better to check lol (Forgot to mention it lean 0,5in on driver side, not sure if the rear are even both side)
  16. Jun 8, 2023 at 9:58 PM
    JETSPD1477
    JETSPD1477 New
    Typical 4Runner
    i think you’re overthinking things.
    front end alignment is made against the thrust angle so the truck tracks properly. you’re not going to kill any wheel or axle bearings. at this moment the truck is properly aligned. take the time to enjoy the truck. consider the simple measures (panhard) to improve the way the rear axle is placed while enjoying it.
  17. Jun 9, 2023 at 5:38 AM
    duc_minh206
    2020 4runner OR
    You right! You should sell it. Joking lol. Ima keep taking it to rock crawling and hopefully one day the axle might address itself :D
  18. Jun 10, 2023 at 1:38 AM
    Flingit1200s
    Flingit1200s New Member
    Drive it and pay attention to tire wear. If you don't see abnormal wear, you are good to go.
  19. Jun 14, 2023 at 4:47 AM
    duc_minh206
    2020 4runner OR
    So apparently, panhard bar (from dobinson ) is slightly longer needed which shifted the rear axle to driver side. Unfortunately, I can’t adjust it any shorter so, no way I can bring the axle back to center, unless I lift the rear higher (2” lifted currently), I guess. I might sound anxious, but I just want to make sure the frame or rear axle not damaged, cuz to be honest, I did a hard pull to recover a truck on the trail lol
  20. Jun 14, 2023 at 5:50 PM
    nova
    nova New Member
    mike
    Prescott Valley - Arizona
    slightly modified LE
    If you kept the OE track bar you could take some measurements comparing the two.
    good luck!
