Alignment Question
Discussion in 'General 4Runner Talk' started by 4Runner5150, Aug 23, 2022.
  1. Aug 23, 2022 at 7:36 PM
    4Runner5150
    4Runner5150 [OP] New Member
    2022 Grey 4 Runner
    XP Predator Package.
    Hi, I am new to this group but I have a 4Runner question. We have a 2022 SR5 with the XP Predator package. We love the vehicle except for one major issue. It pulls HARD to the right. If you take your hand off the wheel, you will be off the road in 3 seconds or less. We took it into the dealership 3 separate times and they keep telling us it is fine. Since then, we have taken it to a local shop, and they work on it, drive it, tell us it is fine. When we pick it up, it is always a lot better for a day or two and then it goes right back to pulling hard to the right. Not really sure what to do at this point. We are not mechanically inclined at all. Any suggestions?
  2. Aug 24, 2022 at 3:24 AM
    AuSeeker
    AuSeeker New Member
    2004 Limited
    Did the dealership take it for a test drive?
    Either way take it back to them and tell them you want it FIXED, it's under warranty they have to fix it, if that dealer can't fix it take it to another dealer or even better contact Toyota Corporate of America and file a complaint on the dealership that can't seem to fix the issue and follow up on it until they get it fixed!!
    Scroll to the bottom of the page and call them, don't just email them, and makes sure you get a case number.
    Also don't volunteer the info of you taking it to an independent garage for this issue, it could void your warranty or they could say the garage damaged something and now it's not their problem!!
    https://www.toyota.com/support/contact-us/
    4runGirl88 and 7385 like this.
  3. Aug 24, 2022 at 3:46 AM
    HarrisNC
    HarrisNC New Member
    2022 Limited
    Rotate the tires. If the right tire is low or bad it will pull that direction. If you move the fronts to the back and it doesn’t fix it then it’s suspension related
