Alignment problems :(
Discussion in '2nd Gen 4Runners (1990-1995)' started by Masolano01, Oct 8, 2021.
  1. Oct 8, 2021 at 1:41 PM
    Masolano01
    Masolano01 [OP] New Member
    1993 4runner
    Someone hit my front driver side wheel while I was parked and messed up my alignment and other things :/ they told me I needed to replace this but couldn’t tell me the part name or anything, what is this?? It’s bent apparently :(( steering arm? I attached a pic of what I’m asking about
    Thanks in advance!
  2. Oct 8, 2021 at 4:24 PM
    trlhiker
    trlhiker Lazy Bum
    1992 4Runner SR5 V6 4X4
    Are you talking about what your finger is touching or the long adjustable rod?
  3. Oct 8, 2021 at 4:27 PM
    Masolano01
    1993 4runner
    The thing my finger is touching!
  4. Oct 8, 2021 at 4:27 PM
    Masolano01
    1993 4runner
    The thing that’s attached to the tie rod i guess
  5. Oct 8, 2021 at 4:52 PM
    trlhiker
    trlhiker Lazy Bum
    I think it is the steering knuckle arm. Not 100% sure though.
  6. Oct 8, 2021 at 5:56 PM
    4scooter19
    4scooter19 New Member
    Oregon
    98 and 86 4Runners
    ^^^ correct
  7. Oct 8, 2021 at 6:53 PM
    https://partsouq.com/tesseract/assets/partsimages/Toyota/4561235130.jpg
    45612-35130
    Not sure! Go to Partsouq.com. Put in your VIN, go to Power Train/Chassis. Pull up Front Steering Gear & Link diagram. Look for the part and part number. Call the dealer and verify part/order. Or order from a discount online TOYOTA dealer (I use McGeorge Toyota)
    They call it a steering knuckle arm.
  8. Oct 18, 2021 at 9:22 PM
    ZARTT
    ZARTT New Member
    Art
    1995 4Runner, Black,Tan Interior, 5spd.,(convert from A340) 207,000 mi., on its 3rd 3VZE.
    Ford Taurus 2 spd. elec. cooling fan, GM CS-144 alternator upgrade. Intimidator AGM battery.
    Hi:
    If you think that the part you are pointing at is bent, and you order the P/N in the above post you will get the wrong item.
    The part number for that item that you are pointing at is 45612-35150, IF your vehicle is a 4Runner frame #VZN130L.
    That frame was produced in the time period 8/89 to 10/95.
    I have a 1995 4Runner that I am dismantling for parts, and I took a photo of that item on the donor car.
    It sort of looks like the one you are pointing at.
    Anyway, I wanted to try to keep you from ordering the wrong item.
    Good Luck
    Art.
  9. Oct 22, 2021 at 6:14 AM
    Masolano01
    1993 4runner
    Hi Art, thank you for your response. You are 100% correct! I actually ordered the part already and fingers crossed it fixes my problem... good luck to you as well sir :)
  10. Nov 2, 2023 at 5:52 PM
    Abunchabananas
    Abunchabananas New Member
    Buncha
    1993 4runner
    Hey, just following up two years later! My 4runner was just swiped this week. They got the front wheel as well.
    Alignment shop couldn't straighten it out and didn't have any details except to take it to a frame repair shop for investigation.
    How did your repair work out?
    Thank you
  11. Nov 2, 2023 at 6:03 PM
    Oakboro, N.C
    May not get a reply from the last replay, Last poster hasn't been online since October 2021.
    Abunchabananas likes this.
