Air pump filter mod?
Discussion in '5th Gen 4Runners (2010-2024)' started by WallyT4R, Sep 12, 2018.
  1. Sep 12, 2018 at 4:51 AM
    WallyT4R
    WallyT4R [OP] New Member
    Has anyone heard of this? I apologize if this has been addressed here. I tried to search for it but did not find anything on it. I just discovered it and it seems to be an issue on the Tacomas. Supposedly the filter inside the air pump will eventually break down and get sucked into the pump and emission valve causing thousands of dollars of damage. Here is a sample video (many out there)
    https://www.youtube.com/watch?v=XO5d4MqZu5I
    So this is a legit issue on the Tacomas. I have not heard of this on the 4runners but that air pump on the truck is the same air pump on the 4. I ordered the filter. It's only for prevention but it can't hurt and it's cheap, so I'm doing it. Here is a part number for the filter. There are other part number examples in the description of the video posted above.
    https://www.amazon.com/dp/B003CJOTSA/ref=as_li_ss_tl?ref=exp_tacomaholic_lv_dp_vv_d
  2. Sep 12, 2018 at 1:54 PM
    j cat
    j cat New Member
    massachusetts
    spacer lift front 1inch
    yes this is on other toyota forums on old trucks with this air pump... the foam is set directly over the pump input..
    the use of this air filter does not sit directly over the input port so debris will get sucked in around the plastic cap.. no gasket or seal the foam has marks on it that seals the intake port.
    I would put some sealer around that cap so no air can get passed the mod filter.
    McSpazatron likes this.
  3. Sep 26, 2018 at 12:55 PM
    Witzkeguy
    Witzkeguy New Member
    2018 4Runner TRD Off Road
    AB5D61BF-CFBD-43F0-96C4-EFA7F5A2A46A.jpg Just took this pic of my 2018 4Runners engine bay. Yep, we have the same filter. Sits between the air filter and the windshield washer fluid fill port.
  4. Sep 28, 2018 at 5:31 AM
    j cat
    j cat New Member
    massachusetts
    I would not flip the air filter so the dirty side is on the intake of the pump.. just like flipping the air filter for the engine ..
    washing the filter with some gentile soap would be good .. it is foam ..
    Pushyguy and SlvrSlug like this.
  5. Oct 7, 2018 at 10:19 AM
    MeanDean
    MeanDean New Member
    Dean
    Rainier, WA
    '18 4R Limited - Magnetic Grey
    Anyone else doing this? Seems like cheap insurance.
  6. Oct 9, 2018 at 1:48 PM
    4runnah808
    4runnah808 New Member
    Manny
    LANAI CITY
    2018 Midnight black 4runnah
    Is it recommended when installing the uni filter can i remove the foam filter too?
  7. Oct 10, 2018 at 1:32 PM
    elnip
    elnip New Member
    Scott
    LC,NM
    2016 4runner Trail P
  8. Oct 4, 2020 at 6:45 PM
    4Runner fun
    Ryan
    Nebraska
    @wall
    Bump due to post in "What have you done with your 5th gen today..." @Cis915 - thanks for bringing this up.
    Very curious about your thoughts after a few years. I read in a few posts (looking for this) that you said it was loud.?
    TIA
    Ryan
  9. Dec 17, 2022 at 7:55 PM
    Potsie
    Potsie New Member
    2022 Army Green 4Runner ORP
    Just an FYI the uni filter up-107 is a dry filter. I've read on various threads of people adding oil to this filter on the tacoma forum,gx as well as the trail4runner comment section. This is a dry filter straight from the manufacturer. The Amazon description of this filter is wrong on its description page in regards to oil
