Air injection wire pulled away from clip!
Discussion in '5th Gen 4Runners (2010-2024)' started by Rmmzmb, Jun 30, 2024.
  1. Jun 30, 2024 at 8:32 PM
    Rmmzmb
    Rmmzmb [OP] New Member
    2014 4runner
    Made a huge mistake. Changing my spark plugs and while removing the 2ndary air injection pump on the drivers side, I accidentally pulled out the wiring harness from the air pump connector. I’m afraid the dealer is going to want to replace the entire wiring harness. Does anyone have any advice for what to do next? Was thinking I could find another clip, but then I’d have to somehow install wiring into the new clip and maybe use a butt/splice connector to join the old wiring to new wiring+ clip. Thank you for any advice, stressin over here.
  2. Jun 30, 2024 at 8:43 PM
    2019 TRDP w/Kangs brah!
    Did the pin come out with it? If so you can bend the lock back out a little and insert it into the proper terminal.
  3. Jun 30, 2024 at 9:03 PM
    Rmmzmb
    2014 4runner
    Not sure what pin there is, I’m basically looking 5 exposed wires and a connector free of those wires. if you mean the clamps around those wires from within that connector, unfortunately that didn’t come out w the wire.
  4. Jun 30, 2024 at 9:14 PM
    AuSeeker
    AuSeeker Old As Dirt
    Skip
    South Carolina
    2004 Limited
    Photos!
  5. Jun 30, 2024 at 9:28 PM
    The metal pin at the end. It locks into the terminal with a little bent piece of metal.
  6. Jun 30, 2024 at 9:50 PM
    Rmmzmb
    2014 4runner
  7. Jun 30, 2024 at 9:52 PM
    You could repin that pretty easily with the right crimp and pins.
  8. Jun 30, 2024 at 9:53 PM
    Rmmzmb
    2014 4runner
    Ooh ok those pins, I pulled them out of the connector to see about re-wiring but they are pretty mangled and crimped w existing broken wire. Do you know where I could find more just like that? upload_2024-6-30_22-53-51.jpg
  9. Jun 30, 2024 at 9:58 PM
    I don’t know the exact name of them but they are common.
  10. Jun 30, 2024 at 11:11 PM
    Doglover2003
    Doglover2003 New Member
    '18 ORP w/KDSS
    820Pcs Electrical Pin Connectors Kit, 420Pcs Car Wire Terminal Connector Pins 1/1.5/1.8/2.2/2.8/3.5mm Non-Insulated Plug Male Female Crimp Terminal Removal Tool Automotive Pin Connector Kit https://www.amazon.com/dp/B0D2DN2GRQ
    You basically need this. Not all of the kit but it has the re-pin tool to make it easy.
    whippersnapper02 likes this.
  11. Jul 1, 2024 at 2:14 AM
    hvac guy
    hvac guy New Member
    MI-FL off roader likes this.
  12. Jul 1, 2024 at 3:48 AM
    AuSeeker
    Skip
    South Carolina
    2004 Limited
    Your biggest issue is knowing which wire goes to which pin, hopefully someone with the same year model can post photos of their connector to help you with that.
  13. Jul 1, 2024 at 6:48 AM
    TRD8
    TRD8 New Member
    North Georgia
    After carefully removing the connector, you can remove the damaged pins using a small flat bladed jewelers screwdriver. If you haven’t done it before, you’ll find the video in the link below helpful. You may find evidence of what the wire color is at the crimp point. Suggest you take lots of photos and be patient.
    Toyota sells repair pins with wires already crimped on if you don’t want to crimp them on yourself. Drawback is they are $10 each and only come in black, so purchasing the pigtail mentioned in the previous post might be the way to go. Advance Auto sells heavy duty butt splices to crimp the other end of the new wire to your injection pump harness.
    https://www.youtube.com/watch?v=k0OLRFWMea0&t=420s
  14. Jul 1, 2024 at 7:00 AM
    crashdb
    crashdb How Did I Get Here?
    Dave
    Manassas, VA
    2022 TRD-OR-P
    Little Tree Air Freshener
  15. Jul 1, 2024 at 1:09 PM
    AuSeeker
    Skip
    South Carolina
    2004 Limited
    Here's link to most all of Toyota's electrical connectors with part numbers and a "how-to", tools needed, etc. in a PDF file, you should be able match your connector by comparing it to the ones shown.
    https://www.toyota-tech.eu/wire_harness_rm/RM06H0E.pdf
