Air Flow Meter
Discussion in '2nd Gen 4Runners (1990-1995)' started by IvanN, Apr 20, 2019.
  1. Apr 20, 2019 at 7:15 PM
    IvanN
    IvanN [OP] New Member
    91 4runner 22re
    Greetings, New Here and I could use some help already. My 22Re was dying when started, from no fuel. I jumpered the ECU, and the fuel pump remains running, and the engine runs, so I am thinking there is no signal from the AFM. Do I need to replace the AFM? Service the AFM? I am no mechanic by any measure, so "What is the next step" is my basic question. Thanks in advance, Ivan
  2. Apr 21, 2019 at 6:34 AM
    HoBoDanny
    HoBoDanny Dude...
    Daniel
    Kentucky
    2004 SR5 V6 4WD 4Runner
    Even with a bad AFM you should get fuel. It wouldn’t run well but it would run. Start tracing wires.
  3. Apr 21, 2019 at 8:41 AM
    IvanN
    91 4runner 22re
    The AFM energizes the Circuit Opening Relay to the fuel pump on the 91s. So tracing the wiring is good advice. Thanks HoboDanny
    Ivan
