Air Bag Rear Spring
Discussion in '5th Gen 4Runners (2010-2024)' started by Gossamer, Aug 26, 2021.
  1. Aug 26, 2021 at 11:32 AM
    Gossamer
    Gossamer [OP] lunarrocktrdpro1
    Middle of America
    anyone with a 21 TRD Pro installed or have knowledge of an airbag kit that will work? Wondering what difference, if any, exists between the rear spring dimensions of a PRO and a standard 4Runner.
  2. Aug 26, 2021 at 12:41 PM
    Like helper bags?
    I'm going to assume you not trying to lower it.
  3. Aug 26, 2021 at 12:42 PM
    Gossamer
    Middle of America
    correct...trying to limit the sag when I pull a 1000lb trailer
  4. Oct 15, 2021 at 1:32 PM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    Did you go with bags?
  5. Oct 16, 2021 at 7:28 PM
    Gossamer
    Middle of America
    No…threw the westcott on…
    Moon Landing[QUOTED] likes this.
  6. Oct 16, 2021 at 10:29 PM
    Jrunr
    Jrunr 2021 TRD Pro
    Jason
    2021 Magnetic Grey Metallic TRD Pro
    Did that help with sag?
  7. Oct 17, 2021 at 5:14 PM
    Gossamer
    Middle of America
    Not really…it is what it is…I’ll just run this suspension until it blows up and then replace it all
  8. Oct 17, 2021 at 6:31 PM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    If his spring rate changed any with the Westcott kit, it was negligible. Two ways to go, bags or firmer springs in the rear. In fact, I'm going to give Eibach a call this week and get some numbers on their PRO rear springs. They say they'll give you a 1" lift, but fail to mention if they're longer, or stronger?
  9. Oct 18, 2021 at 5:20 AM
    Neumie
    Neumie New Member
    MN
    20 Trd ORP
    BFG KO2 stock size
  10. Oct 18, 2021 at 5:24 AM
    Gossamer
    Middle of America
    I've verified with Eibach that their springs are heavier...I believe he said they are 650-700# springs...
  11. Oct 18, 2021 at 5:28 AM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    Thanks. Any idea what the stock springs are rated?
  12. Oct 18, 2021 at 5:31 AM
    Gossamer
    Middle of America
    for some reason, I feel like someone told me or I read it was ~400#...but with the Westcott, I can say the front "feels" more rigid...definitely changed the ride, IMO.
  13. Oct 18, 2021 at 5:36 AM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    Thanks again. I'll attempt to confirm both, and post here.
    Jrunr likes this.
  14. Oct 19, 2021 at 9:46 AM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    Just had a short convo with a guy at Eibach. He says the rear spring is taller than OEM, is rated at 206 pounds(?), and is not recommended for trucks that have been built out. I queried him more and he bailed by transferring me to someone's message box.
    Left message, waiting for call back.....
    EDIT: Reflecting on our convo, he did say the rear Pro springs are rather generic, unlike the front springs on the '21 TRD Pro. fwiw
  15. Oct 19, 2021 at 12:45 PM
    Jrunr
    Jrunr 2021 TRD Pro
    Jason
    It sounds like he was talking out of his rear end….
  16. Oct 19, 2021 at 1:33 PM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    :notsure:
  17. Oct 19, 2021 at 4:53 PM
    jasonmcelroy
    Jason
    San Jose, CA
    2021 Grey Trail
    I installed air bags in mine (the Firestone ones) and have no regrets.
    Majority of the time we use the truck as a DD and it's not built out with any additional sprung weight. When we go camping, we pull a pop-up camper that weights between #1900 and #2400 depending on where we're headed and for how long. The towing had been leading to 1-2" of sag and the accompanying constant flashing by oncoming drivers when night driving.
    So that presents a challenge to any suspension system. I didn't want heavy springs affecting DD use and I can't deal with the sag when towing.
    Bags were $100, took two hours to install myself, do not affect handling when unloaded and deflated, level the vehicle perfectly when towing.
    We took this setup camping two weeks ago in Yosemite and then over Tioga Pass to June Lake and it was perfect. Felt much more stable in towing over the twisty mountain passes.
    Jason
  18. Oct 19, 2021 at 5:06 PM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    Thanks for your input. I'm not against the idea and may well go that way. In fact....probably will.
    jasonmcelroy[QUOTED] likes this.
  19. Oct 19, 2021 at 5:27 PM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    Well, they must be rolling in $$$$$. No call back :mad:
  20. Oct 20, 2021 at 9:48 AM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    Here's the scoop, Per Eibach.
    The Pro's OEM rear spring rate is 184#'s per inch.
    Their 1" lift spring is rated 206#'s per inch.
    They do not have a stand alone spring offering for my situation.
    Their suggested solution is the kit linked below.
    https://eibach.com/us/2000/AK31-82-071-03-02-TOYOTA-4Runner-load-leveling-system
    Note: The kit linked above is 1 of 3 they offer, and is the heaviest. I have a 700 + pound problem, and they only have a 400 pound cure.
    Below, another(Dobinsons) alternative, but they make it quite clear it's a heavier spring rate than my (500 pound constant load or 700 pound when fully loaded)load requires. Hence they do not recommend using them.
    Dobinsons statement: " 700-800 LBS+ Constant Accessory Load. Your vehicle MUST have at least 700-800 LBS of constant rear accessory weight (bumper, tire carrier, roof rack, drawers, fridge, etc), otherwise your vehicle will be over-lifted and will not ride properly. "
    https://www.dobinsonsdirect.com/pro...-runner-5th-gen~yr_2010-2021-suspension-parts
    FWIW and in my opinion based on reasonable input from the 4R gang :D air bags will better serve my needs. Not a decision based on cost but practicality and versatility. imo
    alittleoff, Thatbassguy and nimby like this.
  21. Oct 20, 2021 at 10:17 AM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
  22. Oct 20, 2021 at 11:38 AM
    Yeah, the bags sound better vs Eibach's load leveling kit.
    Although the load leveling kit sounds nice in theory, I have a feeling it would be a pain in the ass to screw that coil spacer up every time you wanted to haul something.
    Thatbassguy and Moon Landing like this.
  23. Oct 20, 2021 at 12:34 PM
    Gossamer
    Middle of America
    i inquired about Air Lift bags...they come with an onboard compressor (optional) and a remote...which is the way I'll most likely go when the time comes. It's around $900 installed...and I was hoping I'd be able to use the compressor for other things as well if I could.
    However, when talking to the company, they told me that the air bags they have spec'd for the 4runner are NOT based on the PRO springs and they asked me to supply them with both internal diameter and height measurements...which I haven't done because I"m lazy. Their concern is that the bag, when inflated, may be too small or too large to adequately do it's job.
    This leads me to wonder if all of the air bags for the 4runner are in a similar situation. May be overthinking it but it's one of those things that I don't feel like messing with and have it be wrong the 4-5 times I use it.
  24. Oct 20, 2021 at 12:38 PM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
  25. Oct 20, 2021 at 1:29 PM
    The stock rear coils for the Pro are the same as the stock Offroad and SR5 trims. There should be no difference.
    The front Pro coils are different from the others.
  26. Oct 20, 2021 at 1:30 PM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    I'm of the understanding that all models of 4Runners have exactly the same inner diameter rear springs.
    To confirm that, go to one of the bag sites and click through their order by vehicle process. What you'll find is there's no designator, by model.
    nimby and Thatbassguy like this.
  27. Oct 20, 2021 at 1:31 PM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
  28. Oct 20, 2021 at 3:32 PM
    HarrisNC
    HarrisNC New Member
    2022 Limited
    I have the Eibach rear spring and it definitely helps with lighter loads, bikes, Home Depot stuff. The rear drops less with my normal load up. I have some sumo springs on my truck, a more progressive rate foam bump stop that helps when loaded. I’d put them in the 4Runner if I towed more. upload_2021-10-20_18-30-35.jpg
    nimby likes this.
  29. Oct 20, 2021 at 3:45 PM
    The PRO rear springs are the same as the OR.
    I see @nimby and @Moon Landing beat me to it. :D
    nimby and Moon Landing like this.
  30. Oct 20, 2021 at 4:15 PM
    ubertoyotax
    ubertoyotax New Member
    Bags can be rough off road, I'd go with stiffer springs
    Moon Landing likes this.
