aftermarket wheels... 17x 8.5 or 17 x 9??
Discussion in '5th Gen 4Runners (2010-2024)' started by Brother708, Apr 20, 2020.
  1. Apr 20, 2020 at 6:58 AM
    Brother708
    Brother708 [OP] New Member
    Austin
    Memphis
    2019 4Runner Off road premium
    *Kings Suspension* Gobi Rack*Shrockworks Bumpers & Sliders*ARB Compressor*Warn Winch* Baja Design lights*
    Will be running a 2.5/ 2 inch king lift and aftermarket bumpers.. what size wheels/tires is the best option for this setup..
    Thanks for the help!
  2. Apr 20, 2020 at 7:38 AM
    Mtbpsych
    Mtbpsych New Member
    So you want what type of tire or what wheel size? You’re asking to different questions here. 17x9 will require a BMC, and some trimming. And as far as tire goes, research. I have the Nitto ridge grapplers and love them. I had the KO2’s before and I’m liking the nittos a lot more.
    Don’t forget to add UCA’s to that setup, especially if you’re going with a. 17x9. You will not get proper alignment, and rub like crazy with stock UCA’s.
  3. Apr 20, 2020 at 7:49 AM
    Brother708
    Austin
    Memphis
    what is your setup? pics? currently have stock UCA but will be going to TC soon. I only want to do this once.. what cutting would be needed with the 9 inch?? a lot of the front fender cutting would already be done since ill have a full shrockwork off-road bumper right? I have found a ton of data on the 17x8.5 with 285/70/17 setup.. but not much on the 9inch wide setup.
  4. Apr 20, 2020 at 7:53 AM
    Mtbpsych
    Mtbpsych New Member
    I have a 3/2 setup right now so I’m level front to back, thinking of going 3” in the rear to get some rake though. If you’re doing a full bumper in the front yes I that would mean that you shouldn’t have any rubbing as your fender liner would be done in the lower half and the aftermarket bumper will open up that portion where the stock bumper would be.
    I got a pretty big BMC done, but I also have 295’s on a 17x9 wheel. On 285’s you wouldn’t need as big of a BMC. You might or might not have to hammer the pinch weld, I’ve been lucky and haven’t had to. I haven’t had any rubbing on mine with what I’ve done. As long as you get a BMC and UCA’s you should be good to go for the 17x9.
    Doglover2003 and travelinscout like this.
  5. Apr 20, 2020 at 8:02 AM
    Brother708
    Austin
    Memphis
    thanks for the info... would I still need the BMC if I just stuck with the common 17 x 8.5 and 285 tire?
  6. Apr 20, 2020 at 8:04 AM
    Mtbpsych
    Mtbpsych New Member
    No problem, and you might or might not. It’s really a hit or miss it seems like, but that’s a still decently wide wheel so I’m going to say you more than likely will.
  7. Apr 20, 2020 at 8:16 AM
    Brother708
    Austin
    Memphis
    so with that thought.. if your going to have to cut anyway.. would you agree it makes sense just to go for the 9 inch lol
  8. Apr 20, 2020 at 8:22 AM
    mynameistory
    mynameistory New Member
    Tory
    The same 4Runner everyone has
    Don't forget about offset. Offset is just as important as width.
    Doglover2003 and nimby like this.
  9. Apr 20, 2020 at 8:25 AM
    Brother708
    Austin
    Memphis
    what do you recommend? -10?
  10. Apr 20, 2020 at 8:27 AM
    Mtbpsych
    Mtbpsych New Member
    Yes, that’s why I went with 295’s. I figured might as well make it a big cut and just go with a 17x9 wheel. And my wheels are also -38mm in offset just to give you an idea of what that looks like. You’re doing everything right to where you can just go with a wide wheel, so personally I’d say do it:notsure: make it how you want it. Full send it instead of wishing you would’ve done something different later on and spending more money on something that can be fine now:spending:
  11. Apr 20, 2020 at 8:32 AM
    mynameistory
    Tory
    For a 9" wheel you'll need at least that. Be careful not to get too exotic here. Excessive negative offset increases your scrub radius (making the wheel rub on the outside edge) and just stresses your spindles and bearings unnecessarily.
  12. Jul 5, 2020 at 2:55 PM
    SoCali_Livin
    SoCali_Livin New Member
    2018 TRD
    Go 17x8.5 w 4.75BS you’ll be good
