Aftermarket stereo resets to default when battery disconnected
Discussion in 'General 4Runner Talk' started by ToyotaDude99, Nov 21, 2025.
  1. Nov 21, 2025 at 5:38 AM
    ToyotaDude99
    ToyotaDude99 [OP] Obsessed with 4Runners... And anything Toyota
    Earth
    1995 4Runner 3.slow
    I have an aftermarket stereo in my 2nd gen 4Runner. It is an Alpine UTE-73BT. (Single DIN) Whenever I disconnect the car battery, the stereo gets completely reset to default. The custom colour I had set is back to default, the radio station presets are erased (that part I can understand), and it resets the Bluetooth settings so I have to forget the device on my phone and re pair it. Anyone know why this is? I've had this stereo in other vehicles and the only thing that it did if the battery got disconnected was reset the radio presets and time. If this is normal for the 4Runner, thats fine but if not, I'm curious as to what's going on
  2. Nov 21, 2025 at 5:55 AM
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    2023 TRD Pro Ice Cap
    That happens on 5th gen W/Stock OEM system. It's electronic that's what happens when the pwr is completely disconnected.:rolleyes:
    ToyotaDude99[OP] likes this.
  3. Nov 21, 2025 at 6:28 AM
    2019 TRDP w/Kangs brah!
    It's the headunit, not an issue with the truck. Not sure why it would change between vehicles but basically it has volatile memory.
  4. Nov 21, 2025 at 7:03 AM
    ToyotaDude99
    Earth
    1995 4Runner 3.slow
    Good to know. The biggest thing that bugs me is the color resetting and it forgetting my phone. Resetting radio stations and the clock? Minor. Changing the color back and re pairing my phone? Inconvenient. But it is what it is. :) I'm not complaining at all, I really like that stereo, just was surprised it resets everything
  5. Nov 21, 2025 at 7:08 AM
    RichInKy
    RichInKy ...but not rich in KY
    Rich
    2004 4Runner V8
    Whenever I have to remove the battery I put jumpers on the cables and a spare battery sitting on the floor to keep power in the system. Then I can swap out the battery with a new one and remove the jumpers. I don't have to reset anything. Just be careful with the jumpers.
  6. Nov 21, 2025 at 8:35 AM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Thats really weird. Mine doesnt do that. It used to but it stopped. My fix was that I threatened to replace it and throw it in the trash if it did it again. Straightened it right up. I would suggest trying this.
    Or some sort of verbal abuse like "a real HU would hold its settings.." or something.
    GL to you hope this helps
  7. Nov 21, 2025 at 8:42 AM
    Borracho Loco New Member
    So what the OP should do is have Chuck Norris threaten the head unit!
    Thacrow[QUOTED] likes this.
  8. Nov 21, 2025 at 10:28 AM
    rockdoc4x
    rockdoc4x New Member
    '24 ORP
  9. Nov 21, 2025 at 2:59 PM
    Seems the unit doesn't store settings in flash memory:
    http://manuals.alpine-usa.com/products/documents/OM_CDE-172BT+CDE-170+UTE-73BT_EN.pdf
  10. Nov 21, 2025 at 5:39 PM
    ToyotaDude99
    Earth
    1995 4Runner 3.slow
  11. Nov 22, 2025 at 8:56 AM
    RichInKy
    Rich
    2004 4Runner V8
    Interesting, but Amazon says it's no longer available.
    There are reviews that the 9V didn't have enough power to last more than a couple of minutes. I guess it depends on how many things it has to power while you're trying to clean the terminals and then swapping the battery. If I were going to use this I would cut off the 9V connector and splice on additional wiring to connect to a 12v LiON project battery. But then if you have the project battery, just connect it to the car's battery terminals while cleaning and swapping batteries. :)
  12. Nov 22, 2025 at 9:45 AM
    ToyotaDude99
    Earth
    1995 4Runner 3.slow
    In in Canada anyway, so I can find other ones off Amazon.ca that are available (and with better reviews)
