Advice on fit and finish of plastic bumper cut
Discussion in 'General 4Runner Talk' started by Austin26, Jul 9, 2023.
  1. Jul 9, 2023 at 9:46 AM
    Austin26
    Austin26 [OP] New Member
    Austin
    5th gen ORP
    While installing a steel bumper, I cut my 5th gen plastic bumper cover. I then used an oscillating orbital sander at 60/80 grit to even the cut line and make the edge pretty.
    However, there's a bit of extra material mostly on the paint side, probably due to the paint holding on more than the plastic. I don't want to sand at an angle to remove the material for obvious reasons, but I don't know how to remove it. Suggestions? Thank you.
  2. Jul 9, 2023 at 9:54 AM
    Is that going to be the finished edge, or are you adding edge trim?
  3. Jul 9, 2023 at 12:01 PM
    Austin26
    Austin
    5th gen ORP
    It's going to be my finished edge. I'm not against some edge trim if it's body colored, though. Anyone know where one would find body colored trim?
  4. Jul 9, 2023 at 12:42 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Maybe just do a super basic sand on the edges, if you haven't already. I cut my bumper with a Dremel then used Cowles Custom Auto Edge Trim. In Canada at Canadian Tire it's black chrome and gold options. But Cowles US website has colors, like orange and red. That edge kinda disappears with the bumper installed, maybe color instead of black would look cool I kinda wish I tried white on mine. Otherwise I don't see anyone paint matching.
    Goodluck!
    https://cowlesproducts.com/store/Cowles®-S37525-Custom-Red-Molding-or-Trim-1-4-x-20-p147363399
  5. Jul 9, 2023 at 1:41 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Hand sand it and take your time. Id use edge trim though, it just makes it look more finished.
    MeefZah likes this.
  6. Jul 9, 2023 at 4:22 PM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    2020 GX460
    TLCA #25089
    I think body colored edge trim would be weird looking. I suggest the black stuff, much like jeans, you can wear black accessories with anything on your truck....
    Austin26[OP] likes this.
  7. Jul 9, 2023 at 11:01 PM
    If your bumper is going to be black, you won't notice black edge trim.
  8. Jul 10, 2023 at 1:31 AM
    Austin26
    Austin
    5th gen ORP
    You're probably right. I think I'll just get edge trim and call it a day. Probably just over thinking it.
  9. Jul 10, 2023 at 3:14 AM
    djwantke and Austin26[OP] like this.
  10. Jul 10, 2023 at 6:33 AM
    NIW you have us wanting to see the final result. Looking forward go the installed bumper pics.
  11. Jul 10, 2023 at 7:56 AM
    Austin26
    Austin
    5th gen ORP
    I don't know what NIW means but here is a picture. I will take it off again to level it, then install a windshield washer skid plate.
    hossler1788 and Dabigono like this.
  12. Jul 10, 2023 at 8:29 AM
    Hans Moleman
    Hans Moleman New Member
    SF Bay
    fyi…taping with masking tape then cutting would have prevented this. Scoring the cut line with a sharp knife before cutting would have helped too.
    nimby likes this.
  13. Jul 10, 2023 at 10:26 AM
    That was supposed to be Now, not NIW. Fat finger typing...
    That looks great. To be honest, I can't see any issue with leaving it as is, OR adding edge trim. Judging from your photos, you really can't see much of what you're describing in post one, at least from a ways back.
    That is a lot of bumper right there...
  14. Jul 10, 2023 at 3:35 PM
    Austin26
    Austin
    5th gen ORP
    Ha, I just figured NWI meant something online as I'm out of touch with most of that.
    It looks massive but it really isn't in person. In fact, it looks tightly snugged up against the front. You can't really see the top of the hoops while driving, even. Here is a side view which may help illustrate my point. Plus keep in mind my engine skid is right below the bumper so it looks like one big thing.
  15. Jul 10, 2023 at 4:00 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Looks great! Which brand is the bumper? And what did you do with the tss?
  16. Jul 10, 2023 at 4:59 PM
    Austin26
    Austin
    5th gen ORP
    Thanks. CBI Adventure bumper 2014-2019 fitted to a 2022 ORP. DIY TSS relocation, have a thread about it if you're interested. Took some adjusting but got it right.
