Add KDSS?
Discussion in 'General 4Runner Talk' started by DKN, Sep 6, 2019.
  1. Sep 6, 2019 at 8:22 AM
    DKN
    DKN [OP] New Member
    2020 TRD PRO OR - Super White
    2018 TRD Off-RD...no KDSS. Can you add KDSS?
  2. Sep 6, 2019 at 8:41 AM
    Dark Knight
    Dark Knight Get off my lawn
    As far as I know the frame is slightly different on a kdss model.
  3. Sep 6, 2019 at 9:33 AM
    Dillusion New Member
    KYle
    Might as well sell/Trade-in and get one with since your is still new.
    Toffees and gunsnob like this.
  4. Sep 7, 2019 at 4:56 AM
    Toffees
    Toffees Stuff and things
    Micah
    LA
    16 LE
    Eh?
  5. Sep 7, 2019 at 4:58 AM
    Toffees
    Micah
    LA
    16 LE
    You *should* be able to but I have no idea what other installed equipment may need to be adjusted as well. And it’s probably a chore to install, but at least you should be able to find a system taken off a truck at low cost.
  6. Sep 7, 2019 at 5:52 AM
    Dark Knight
    There are brackets welded on the frame front and rear for the kdss sway control cylinders to mount to. Not sure a non-kdss has those brackets.
    Toffees[QUOTED] likes this.
  7. Sep 7, 2019 at 6:49 AM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    That would be a project that just doesn’t make sense. Financially and otherwise.
    WallyT4R likes this.
  8. Sep 7, 2019 at 7:03 AM
    Toffees
    Micah
    LA
    16 LE
    Yep. And moving around other installations I’m sure. This is like the “can I add a 3rd row”. Yes, you can, but it’s probably not worth the effort.
  9. Sep 7, 2019 at 7:06 AM
    Dark Knight
    Exactly. Not worth it.
