Acquiring a ‘02 SR5 4x4, upgrading bumpers, roof rack, tires; suspension - Ironman vs Bilsteins
Discussion in '3rd Gen 4Runners (1996-2002)' started by Hanley1000, Oct 31, 2024.
  1. Oct 31, 2024 at 12:19 AM
    Hanley1000
    Hanley1000 [OP] New Member
    Tom
    88 4Runner Deluxe grey
    Hello
    I’ve had some experience using Iron Man front and rear shocks with overload springs… Tempted to do it again, but curious as to whether the 5100 or 6112 series Bilsteins would be a better alternative. Anyone have experience or suggestions?thanks
    Tom
  2. Oct 31, 2024 at 12:21 AM
    Hanley1000
    Tom
    I put the Iron Man overload shocks in spring into an 05 LX 470… I’m about to make over an ‘O2 stock 4Runner SR5…
    Although I have owned a 1st gen SR5 4Runner, beefed up the front end w/ Sumo springs and ran Bilsteins in that, I never owne a 3rd gen 4Runner and I know they’re already basically a Tacoma looking a bit more sedate. So curious what other folks experience has been and what might be recommended… Thanks
  3. Oct 31, 2024 at 4:37 AM
    Spare Parts
    Spare Parts New Member
    Southern Maine
    22 LR ORP
    Bilsteins tend to be more recommended on here, however I went with iron man on my 5th gen, so far happy with them. This is the first time I have ever upgraded a suspension, so I have limited experience.
    Hanley1000[OP] likes this.
  4. Oct 31, 2024 at 8:04 AM
    Hanley1000
    Tom
    Hey thanks for sharing those thoughts….
    Spare Parts likes this.
  5. Jan 2, 2025 at 3:31 PM
    Hanley1000
    Tom
    So I have some updates to report (on the 3rd gen 4Runner transformation re: front end suspension) ....as usual, more questions and a few painful & costly lessons!
    I have some issues on the front end - due to the lifting -
    and had intended to replace the front Upper Control Arms (UCA) with SPC 25460s but IMMEDIATELY discovered that I would still have pretty major caster and camber issues (not Toe)...
    TO be clear, after initially installing the new SPC UCA, the camber and caster were WAY out and the tires were canted at such a ridiculous angle, not even safe to drive, let alone enjoy the ride....so I have temporarily removed these SPC UCA items until I find a wise compatible LCA solution.
    Suggestions?
    Q: Anyone have a reasonable cost, but quality / long term reliability solution? Im told by SPC that I need to likely replace the lower control arms too, but I want to do that with a careful wise compatible choice....unfortunately, SPC does NOT sell a compatible lower control arm product.
    Anybody have experience?
    I did install front end IronMan America overload shocks...(they look amazingly robust, and did in fact lift the front end about 3", more or less.
    I then added Sumo springs in the front.
    I also added new Iron Man rear springs (of the 3 choices, went with the medium load range), and Timbrens, and the rear shocks also from IronMan...I needed to add an additional rear spring spacer to give proper rake / angle to offset the front, and also adjusted the (rear) pan hard bar, and replaced rear control track bars as they were pretty worn out.
