Accidentally used 0W-16 instead of 0W-20… Do I need to change oil over again?
Discussion in '5th Gen 4Runners (2010-2024)' started by torred, Apr 7, 2024.
  1. Apr 7, 2024 at 3:07 PM
    torred
    torred [OP] New Member
    22 Black 4Runner TRD Off Road
    Hi there. Newbie here looking for a bit of advice. I recently bought a 2022 4Runner ORP, and changed my own oil for the first time today.
    Successfully drained the old oil, replaced my filter, and put skid plates back on. I then moved onto refilling with my new oil. After getting the new oil topped off, realized I made a mistake…
    When buying my new oil, I accidentally bought 5qt of 0W-16 instead of 0W-20 (as specified in the manual). The other 2 qts I bought were the proper 0W-20, so I’ve currently got 5qt of 0W-16, and 1.6qt of 0W-20 in my engine.
    Do I need to drain the whole thing and refill with 0W-20? Or am I safe until my next oil change? (Planning to change at 5k intervals).
  2. Apr 7, 2024 at 3:47 PM
    4RunTM
    4RunTM New Member
    TM
    CA
    22' SR5P
    I wouldn’t push it until the next oil change interval but I also wouldn’t rush to redo it. Get to it when you can?
  3. Apr 7, 2024 at 4:11 PM
    2018 Limited
    2018 Limited New Member
    BDR
    2018 Limited
    As you are aware 0W16 is thinner. If it were my vehicle I would change it out as soon as possible but I’ll put a torque wrench on a wood lag.
    Saker, Superdave1.0, Sin4R and 3 others like this.
  4. Apr 7, 2024 at 4:18 PM
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    I would change it out.
    Superdave1.0, Sin4R, icebear and 6 others like this.
  5. Apr 7, 2024 at 4:23 PM
    As much as it sucks, I'd agree with the others. It might be fine, but it's not worth risking it.
    kmeeg and Han4Run like this.
  6. Apr 7, 2024 at 4:27 PM
    torred
    Thank you all for quick responses! I’m going to change it out. It’s worth the bit of extra money and time to avoid the risk. Appreciate it!
    Dan's 4runner and Thatbassguy like this.
  7. Apr 7, 2024 at 4:32 PM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    Just mix in some corn starch to thicken it up
  8. Apr 7, 2024 at 4:33 PM
    garoto
    garoto New Member
    $18k engine vs $35 oil. Easy decision.
    Superdave1.0, Sin4R and Dan's 4runner like this.
  9. Apr 7, 2024 at 4:36 PM
    torred
    if it works for sauces, it must work for engine oil… right? ;)
    Spare Parts, icebear and Thatbassguy like this.
  10. Apr 7, 2024 at 4:38 PM
    Good call!
    :rofl:
  11. Apr 7, 2024 at 4:47 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    An SAE oil weight difference of 4 in a 4Runner is going to change literally nothing.
    Also you could just drain a quart and fill with 0w-30 and it probably would be pretty dang close to 0w-20.
    ThatOneGuy, jgalt, RUNNER4DAN and 2 others like this.
  12. Apr 7, 2024 at 4:53 PM
    Change it asap and learn from the experience.
    BS67 and Thatbassguy like this.
  13. Apr 7, 2024 at 5:07 PM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    Real chefs use butter.
    Superdave1.0 and Thatbassguy like this.
  14. Apr 7, 2024 at 5:10 PM
    catbrown357
    Tempe
    2011 Limited 4WD
    Since you're changing it again: before you put the skid plates back on; refill with new oil, start the engine, check for leaks at the filter and drain plug.
  15. Apr 7, 2024 at 5:52 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    I didn't even know there was a 0w-16, is that for electric motors? Haha
    Jere39 and alittleoff like this.
  16. Apr 7, 2024 at 6:23 PM
    torred
    I’m telling you, I SWORE I grabbed 0w-20 off the shelf… somebody must have swapped it while I wasn’t looking :(
    Saker likes this.
  17. Apr 7, 2024 at 6:27 PM
    5thToy
    5thToy New Member
    Northern Nevada
    2019 SR5P
    If it were me, I would probably drain, leaving the volume of 16 in the new filter and housing, then re-fill/top off with 0W-20.
  18. Apr 7, 2024 at 6:34 PM
    Tooly
    Tooly New Member
    Okanagan, BC Canada
    Close haha, my Prius Prime uses 0W16
  19. Apr 7, 2024 at 7:37 PM
    You will probably get real good gas milage.
    icebear and Superdave1.0 like this.
  20. Apr 7, 2024 at 8:19 PM
    Up, down and all around!
    Actually, chefs prefer to just add flour and make a nice Roux...:D
    Saker and Schlappesepple like this.
  21. Apr 7, 2024 at 8:22 PM
    Superdave1.0
    Superdave1.0 New Member
    LX470, 2025 Civic Si
    Yep, change it. I'd definitely leave the filter alone though. So add slightly less oil than a normal oil change.
  22. Apr 7, 2024 at 9:13 PM
    I think newer Honda’s use 0-16 too.
  23. Apr 7, 2024 at 9:18 PM
    Superdave1.0
    My 2022 civic 2.0L and now my 2024 1.5L turbo civic both use 0W-20. Maybe the hybrid models use 0W-16. Corolla and Camry I think use 0w-16. These oils are going to be water soon!
    :bananadead:
    4RunTM likes this.
  24. Apr 7, 2024 at 10:29 PM
    ^Toyota is already there:
    icebear and Superdave1.0[QUOTED] like this.
  25. Apr 7, 2024 at 11:20 PM
    Yotaholic
    Yotaholic New Member
    Olympia, WA
    OW-20 is already so thin for this truck and you went 16 lol. Change it. Keep the filter as it is, just change the oil. And replace that stupid OEM skid plate with RCI to make oil changes easy
    ualfltdispatch likes this.
  26. Apr 7, 2024 at 11:25 PM
    Yotaholic
    Olympia, WA
    I have been using TGMO but I am considering Castrol Edge next oil change.
  27. Apr 7, 2024 at 11:25 PM
    Yotaholic
    Olympia, WA
    That's for the Corolla GR I think, or maybe Supra
  28. Apr 8, 2024 at 4:30 AM
    NYRunner322
    NYRunner322 New Member
    New York
    2022 ORP Midnight black
    Oil is cheap, engines are not. Why take a chance. Change it
    Yotaholic likes this.
  29. Apr 8, 2024 at 5:35 AM
    rmiked
    rmiked New Member
    Fort Mill, SC
    My wife has a 2023 Rav 4. It uses 0W-16.
  30. Apr 8, 2024 at 5:42 AM
    whododat
    whododat New Member
    optometristsnearme.com
    :rolleyes:
    3JOH22A likes this.
