ACC/Ignition controlled Fuse Block
Discussion in '5th Gen 4Runners (2010-2024)' started by clt_ah4runner, May 22, 2024.
  1. May 22, 2024 at 10:55 AM
    clt_ah4runner
    clt_ah4runner [OP] New Member
    aaron
    Looking for ideas and what anyone has done for an accessory/ignition powered fuse block. Would rather just have 1 wire tap in the factory fuse box that i can hook to a relay and add accessories I only want powered when vehicle is on (DRL, GMRS radio, etc) without taking up inputs on my switch pros. I already have an always hot blue seas fuse block but want to add a switched one. what relay are you using? where did you mount? any pics would be great!
    Old Tanker and wing2 like this.
  2. May 23, 2024 at 2:06 AM
    wing2
    wing2 New Member
    Richard
    2024 SR5 Premium
    I use products from this company on my motorcycle. Good quality.
    https://electricalconnection.com/index.php/product/universal-power-plate-fuse-block/
  3. May 23, 2024 at 6:45 PM
    Old Tanker
    Old Tanker New Member
    Keith
    "Matilda" 2019 ORP
    Front: Hefty. Rear: LFD. Sliders: RSG. Armor: Hefty and Bud Built. Tires: KM3. Switchpro.
    Watching. This is a project I'll probably be doing myself.
  4. Jun 2, 2024 at 3:12 PM
    Grillmastertoo
    Grillmastertoo New Member
    AL
    2024 TRD PRO White
    What fuse did you tap into for an alway on fuse?
  5. Jun 3, 2024 at 9:36 AM
    clt_ah4runner
    aaron
    Update....Added a blue sea safety hub 100 in to handle high current accessories. Let's me eliminate in line fuses on the ARB and cleaned up the compressor wiring with some blaze offroad harnesses. The Kaon Australia tie down tray for the Prado/FJ fits perfect and holds both the SH100 and a 4 terminal block for the low amp fuses from the blue seas connector plug. The main difference is that this fuse block is ignition controlled by my primary battery as opposed to the always hot 6 circuit blue seas fuse block which is powered from the secondary battery. Because the sdoffroadmt switch pros tray covers my factory fuses, this makes it easy to tap into accessory power. The Kaon bracket is supported by a powertrays dual CB battery tie down which holds a 135a CB into a high amperage relay that is connected to the IGN via an add-a-fuse. Now my Switch Pros 9100 blue wire is attached to the terminal block along with my morimoto DRL power. No more fuse taps. just hook up to that terminal block and anything I want only on when the vehicle is running is good to go. Also that Victory4x4 engine cover is fire
    20240602_184356.jpg 20240602_184535.jpg 20240602_184523.jpg 20240602_184513.jpg
    T in Texas and Old Tanker like this.
