ABS and brake light illuminated after changing rear caliper
Discussion in '5th Gen 4Runners (2010-2024)' started by 2001drummerboy, Oct 10, 2023.
  1. Oct 10, 2023 at 12:56 PM
    2001drummerboy
    2001drummerboy [OP] New Member
    2016 4runner limited
    Just changed left rear caliper.
    Now I have abs and brake light on.
    What did I do wrong?
  2. Oct 10, 2023 at 1:43 PM
    Welcome to the forum, Mark.
    Have you ensured that the brake fluid level is at the correct level/brakes bled properly.
    Did you have any issues with the rear ABS sensor while replacing the caliper?
    I would double check anything in and around that area since the light just came on after working in that area.
    Please provide updates if you locate the issue.
  3. Oct 10, 2023 at 3:05 PM
  4. Oct 10, 2023 at 3:54 PM
    DesertSurfer
    Welcome to the forum!
  5. Oct 11, 2023 at 12:58 AM
    Welcome.
  6. Oct 11, 2023 at 10:05 PM
    Welcome! What steps did you take to change it? That will help identify if there was an error on your part. Also, how are the brakes working currently?
  7. Oct 12, 2023 at 2:55 AM
    Dabigono
    Dabigono Just Joined
    2020 4Runner
    Yup, double check fluid level and the ABS sensor. BTW, welcome
