A/C only works whenit is less than 80 degrees outside
Discussion in '4th Gen 4Runners (2003-2009)' started by Geo812, May 25, 2025 at 8:33 AM.
  1. May 25, 2025 at 8:33 AM
    Geo812
    Geo812 [OP] New Member
    Sunday
    George
    99 4 Runner for fun
    Sunroof delete
    Hi,
    I finally bought a gen 3 4runner last June and on the drive home with it the A/C worked for about 15 minutes and then started blowing warm air. I took it to a shop and they evacuated the system and refilled the freon andit worked great for the 15 minute drive home and when i drove it the next day, the A/C worked until it got to be over 80 outside. Any ideas?
  2. May 25, 2025 at 12:15 PM
  3. May 26, 2025 at 10:47 AM
    Buckaroo
    Buckaroo New Member
    2005 Ltd T4R 4WD V6
    You likely have a leak in your system. Did they put dye in when they recharged it? FYI - this is the gen 4 forum.
    LOSTR4 likes this.
  4. May 26, 2025 at 2:23 PM
    LOSTR4
    LOSTR4 New Member
    Just a couple
    Leaking condenser is my guess... it gets heat-soaked and blows warm air... junk yard time!
  5. May 26, 2025 at 3:27 PM
    They wouod have been able to "test" the pressure and see if its leaking. I got a Denso from Ebay ready to install. After installation by an AC tech. It was not cycleing correctlly and he was able to diagnose the expansion valve failed.
  6. May 26, 2025 at 3:45 PM
    The hotter is gets outside. The BETTER the 4R runs. Its like it used the ac system to cool the engine compartment and motor. I can make ice cubes inside when its 100+ in the sun.
  7. May 27, 2025 at 6:18 AM
    take it back to the shop who just dumped freon in it. You paid them to diagnose and fix it
    LOSTR4 likes this.
