99 4Runner No Crank No Start
Discussion in '3rd Gen 4Runners (1996-2002)' started by jajankenpo, Jul 20, 2022.
  1. Jul 20, 2022 at 5:36 AM
    jajankenpo
    jajankenpo [OP] New Member
    Jacob
    1999 Toyota 4Runner 2.7l base
    So my 99 4Runner 2.7l base isn’t cranking or starting. Originally, I was driving down the road and it just cut off on me and wouldn’t start after that. Had it towed home. It would crank after that, but no start. Thought it had something to do with the starter, so took that off and got a new one, now it’s not cranking and I’m throwing a PO335 and PO340.
    New starter is getting power when attempting to crank, the engine is turning over by hand, figure it might be something to do with the ignition switch, but between that and the codes, I’m kind of at a loss on next steps. Would definitely appreciate some guidance :D
  2. Jul 20, 2022 at 5:59 AM
    Daddykool
    Previous starter turned, but replacement doesn't? I'd start there - you need that before anything else. Maybe you got a defective starter or missed something on the installation. Check the fuse first. Next, reconnect the old one and see if it turns. Keep in mind the original problem is that the truck died in the middle of driving. A failed starter won't cause that problem.
    Codes indicate crankshaft and camshaft sensors, which may simply be due to the fact it's not cranking, since they showed up after the starter replacement. Could also be a timing chain break. Not familiar with that engine but there may be a cover you can remove to view the chain.
    Could be a fuel problem.
  3. Jul 20, 2022 at 6:28 AM
    jajankenpo
    Jacob
    Will double-check after work and let you know the results.
    funny enough is that the new starter DID crank multiple times after installation. Thought it was a fuel issue, so went to listen for the fuel pump and asked gf to turn the key for me. She didn’t even get to crank it before it just stopped working, despite the fact that I had cranked it just thirty seconds earlier.
  4. Jul 20, 2022 at 6:48 AM
    Parts store starters are trash. Replace it with your old one or one from a junkyard TOYOTA or a new TOYOTA one.
    Lol. Sorry...Anyways, a full stop\shutdown like that while running is going to be a few suspicious actors:
    Fuel Pump. Maybe a clogged fuel filter or bad fuel pressure regulator.
    Timing is off. Belt\chain broke...crank or cam sensor went tits up. ECU has no idea when to spray and spark so it shuts things down.
    ECU dropped dead. Probably the least possible on a TOYOTA.
    First thing...get it cranking again and go from there.
    Daddykool likes this.
  5. Jul 20, 2022 at 7:08 AM
    jajankenpo
    Jacob
    LOL no worries- previous owner let little brother borrow it and little bro took it mudding without the shield on the bottom. There’s still mud caked over everything, and the starter is no exception. Feels like I eat dirt every time I touch any surface underneath the car lol.
    I’m fairly new to DIY mechanics, so decided to put a new starter on because it was having issues starting when hot (haha ). Been reading up on that and saw some people say to clean fuel injectors, some said change starter, and when this happened decided to try new starter just in case.
    But, tested the starter relay and that’s got continuity when energized. Tested the solenoid when cranking and that’s getting powered. Still got to clean the old one and find the time to pop it back on, but definitely won’t be right now. Will update once I get to that stage.
  6. Jul 21, 2022 at 9:42 PM
    jajankenpo
    Jacob
    Okay, so update: put the old starter in and it started cranking, so 100% user error on that and thank you for suggesting. Codes are gone too. However still facing the no start issue, so back to square 1ish.
    will check the fuel pump and filter tomorrow or when I get additional time and will continue to update when I find the issue.
  7. Jul 21, 2022 at 9:51 PM
    Well timing or fuel are probably the two top contenders.
    I'd do a fuel pressure test on the fuel rail. No fuel...no go.
    If fuel pressure is good, you'll need to look up how best to troubleshoot timing.
    When was the belt changed last? It didn't maybe break did it?
    Since the codes went away after the starter was changed, I'm thinking the ECU is fine.
    Not sure if a bad MAF would cause a no start. I think you would get codes though.
    Most anything else if it was wrong, it would try to start but run poorly.
  8. Sep 13, 2024 at 4:10 PM
    Poly3rdGen
    Poly3rdGen New Member
    1999 Toyota 4runner 2.7
    None
    I'm experiencing this same issue. No crank No start. All acc turn on when key is turned. Changed starter and ignition switch. It only happens when car is hot. After waiting for car to cool, it turns on. Any help would be appreciated.
  9. Sep 18, 2024 at 11:11 AM
    With a random no crank\nostart, first culprit I look at is usually the battery cables. Make sure they are not corroded under the insulation. I take the battery cables off and bend them feeling if they feel "crinkly" and even peeling back some insulation to see what things look like.
    PhantomTweak likes this.
  10. Nov 9, 2024 at 1:26 PM
    1bubbleoff
    1bubbleoff New Member
    99 4runner limited 2wd 3.4V6
    Very similar situation and approach to fix. I smacked something in the road, resulting in a jarring impact on front end that caused my 4runner to die and hasn't started since. No crank, no nada. Headlights, dash warning light, horn all the things still light up and don't dim or fade when key is turned. In fact when key is turned the AMP30 Amp fuse blows. Waved my white flag and had it towed to a dealership... short to ground issue; engine room wire #2 is the culprit along with the need to replace starter relay and blown AMP30 fuse. In conclusion I'd suggest looking into a possible short to ground
