'97 - leaking steering bellows?
Discussion in '3rd Gen 4Runners (1996-2002)' started by Nola97, Jan 5, 2023.
  1. Jan 5, 2023 at 5:09 AM
    Nola97
    Nola97 [OP] New Member
    '97 4Runner 4 cyl manual trans
    none
    I have been slowly leaking steering fluid for some time. I have tried "Lucas Stop-Leak" to no avail. This is not my daily vehicle so I have not attempted to investigate the problem. I went to run some errands in it recently and noticed a pool of fluid under the right front wheel. Through my i-net searches I see that the steering bellows can leak fluid?
    What causes this? How can I confirm the issue and suggestions on repair?
    Thanks!!! John
  2. Jan 5, 2023 at 6:55 AM
    ^The bellows is just a dust boot for the inner tie rod joint. The shaft seal where the steering rack exits the housing will wear with age and cause the fluid to leak into the bellows. If the shaft seal leak is severe, fluid can drip onto the ground.
    Need to diagnose it properly. If the pool is under a wheel, you sure it's power steering fluid and not brake fluid? Is the PS reservoir level going down?
  3. Jan 5, 2023 at 6:59 AM
    Nola97
    none
    Yes, it's power steering fluid and the reservoir level is going down.
  4. Jan 5, 2023 at 7:01 AM
    ^Cut one of the bellows clamps and see if there's fluid inside. Normally it should be dry. If there's PS fluid inside, replace the rack.
  5. Jan 5, 2023 at 7:07 AM
    Nola97
    none
    Can you please be more specific when you refer to replace "the rack"? My mechanic skills are very limited.
  6. Jan 5, 2023 at 7:13 AM
    ^If there's PS fluid inside the bellows, replace the whole steering rack & pinion assy. It looks like this
    The part costs $300-500 depending on whether it's aftermarket or Toyota OEM, plus install labor and alignment.
  7. Jan 5, 2023 at 7:18 AM
    Nola97
    none
    Is this a complicated job? In other words, could I "you-tube" the install or should I trust it to a professional?
  8. Jan 5, 2023 at 8:06 AM
    ^Not complicated - the rack is a lot more accessible in the 3rd gen than in later 4Runner generations. However, being 26 years old, things like the steering shaft joint and fluid line fittings could be rust seized. A shop would be better equipped with air hammers and torches to deal with that. Going through a shop also makes warranty easier if the replacement rack develops problems.
  9. Jan 5, 2023 at 8:10 AM
    Nola97
    none
    Thanks for the advice! I'd hate to attempt the install and get stuck midway.
