80k maintenance questions
Discussion in '4th Gen 4Runners (2003-2009)' started by StayCav, Jun 23, 2016.
  1. Jun 23, 2016 at 6:33 PM
    StayCav
    StayCav [OP] New Member
    StayCav
    2007 Silver XSP 4runner 80,000
    none...yet
    Hello,
    1st time 4th generation owner. Super clean truck (except for the smoker smell it has)
    Hope all are well. My XSP has 80,000 miles on it. It's toyota certified. I've owned a 3rd generation 4Runner and a 2008 tacoma. My question is what do you guys feel maintenance wise is needed at 80,000? Is this leather/suede hard to take care of? What could I do for the cig. Smoke smell. Thanks
  2. Jun 24, 2016 at 11:47 AM
    Bob
    Bob Member Staff Member
    Bob
    Regarding the cigarette smell, put a small 8oz perforated bag of ground coffee under all of the seats for a couple of weeks. Shampoo the seats as well and you should be good.
    Large, RonT4R and Molina4*4 like this.
  3. Jun 26, 2016 at 7:29 AM
    wnelax04sr5
    wnelax04sr5 New Member
    Ethan
    CT
    2004 SR5 4X4 Galactic Gray
    80k you don't really need to do anything, since its certified every major item has already been checked by the dealer to see if it needs replacement
  4. Jun 27, 2016 at 9:31 AM
    T-Rex266
    T-Rex266 Moderator Staff Member
    Check your owners manual it should include the mileage maintenance items.
    Bob likes this.
  5. Jun 28, 2016 at 4:57 AM
    StayCav
    StayCav
    none...yet
    Thanks for the info. I like the coffee idea. My 3rd generation had 100+ on it, however my tacoma (4.0) was low mileage when I sold it.
    I do have another question. My XSP has the 20 inch wheels. Im not familiar with this large of a wheel. Seems like it floats a little. Could just be the width. I was able to replace the AC panel bulbs thanks to this forum. Appreciate that. I was thinking about replacing factory shocks with the 5100, I also wanted to take some rake out the front. Your guys thoughts? Thanks. Take care
  6. Jun 28, 2016 at 7:01 PM
    wnelax04sr5
    Ethan
    CT
    all good ideas, before you pull the trigger its good to think about future plans for the vehicle so you can pick the best option
  7. Jun 28, 2016 at 7:08 PM
    StayCav
    StayCav
    none...yet
    Thanks. I think my tires are probably the culprit. They have 1/4 tread left. Apparently something the local toyota dealer thought was a go on the check list. Are the 5100 shocks good for additional height on the front as far as ride? Money is an issue lol. Don't have alot right now. I have good local mechanic, so I'm taking it there for a second once over. So an odd thing. When I replaced the AC panel bulbs I noticed that there were no screw bolts holding the radio bracket. Is this an odditie?
  8. Jun 30, 2016 at 4:17 AM
    RonT4R
    RonT4R New Member
    Ron
    Virginia Beach
    2007 4runner SR5 4WD
    Mine with 5100's all around. Mine are set to the middle setting and it leveled out the front a lot better.
  9. Jun 30, 2016 at 5:59 AM
    StayCav
    StayCav
    none...yet
    Ront4r
    Thanks for the post. That's what I was looking for. I like the look. Where you able to go up a size in tire up front? If you wanted to. I like my 20 inch wheels however, I would like more rubber surrounding them.
  10. Jun 30, 2016 at 8:16 AM
    RonT4R
    RonT4R New Member
    Ron
    Virginia Beach
    I could probably go up a size.... I'm running stock size tires atm.
  11. Jun 30, 2016 at 1:51 PM
    StayCav
    StayCav
    none...yet
    Ok. Thanks for the help.
