6th Gen First Oil Change, WOW!
Discussion in '6th Gen 4Runners (2025+)' started by Old Geezer, Dec 8, 2025.
  1. Mar 2, 2026 at 7:09 AM
    #61
    Old Geezer
    Old Geezer [OP] New Member
    Central Indiana
    2025 Hybrid, Red
    Mods? None. Been there, done that. I like this one stock.
    Wipe the dipstick with a white paper towel, you can tell how dark it is. For reference, put a drop of new oil next to it.
    Not real scientific but you'll get the idea.
  2. Mar 2, 2026 at 7:10 AM
    #62
    Can you share some pictures of it?
    ToyotaDude99 and Archer like this.
  3. Mar 2, 2026 at 7:14 AM
    #63
    Old Geezer
    Central Indiana
    2025 Hybrid, Red
    I haven't recycled the old oil yet. I can get a photo later.
  4. Mar 2, 2026 at 7:15 AM
    #64
    Steve40th
    Steve40th New Member
    sTEVE
    Nothing wring with preventive maintenance.
    Cheaper than down time for repairs
  5. Mar 2, 2026 at 7:23 AM
    #65
    My dad has this same turbo engine in a newer Highlander he bought. We’ve been changing the oil at around 4k intervals, give or take. The color of the oil on the dipstick shows as a dark maple syrup color at that mileage, and it’s still transparent on the dipstick. How’s that for scientific!? ;)
    The color I’ve see thus far hasn’t concerned me too much, being a turbo with DI. But it does reinforce the idea of getting it done before 5k for sure.
    Full disclosure: I don’t have previous experience with modern tiny turbos, so I couldn’t say what’s normal. That said, I did own a 2011 Optima which I mainatined at 7500 intervals. That oil looked like gear oil with that mileage (no joke, it had that black-gray look, completely opaque to light).
  6. Mar 2, 2026 at 8:00 AM
    #66
    my cousin has a 4 cyl turbo Tacoma and he changes oil every 5000 miles. Turbo cars degrade oil quick
  7. Mar 2, 2026 at 12:45 PM
    #67
    FourBelugas
    FourBelugas New Member
    23 white ORP
    more heat + higher pressure + direct injection, no way around it. The T24A FTS has supplemental port injection but guess where the washed off carbon build up goes...
  8. Mar 2, 2026 at 1:22 PM
    #68
    Old Geezer
    Central Indiana
    2025 Hybrid, Red
    OK for what it’sIMG_7028.jpg worth. I haven’t recycled oil from either oil change but each one is in a separate gallon jug so I know which is which. The top oil is fresh oil. The middle one is from the 3000 mile oil change. The bottom was from the 1500 mile oil change.
    This is high-tech, highly scientific since I took a screwdriver and dipped it in each of the three oils and wiped it on the paper towel.
    The new oil has color to it I think only because it’s laying on concrete and you can see the concrete thru the paper towel. Otherwise, it’s mostly clear.
    As someone else mentioned, you can’t really see it on the dipstick but you can tell the difference when you wipe it on a white paper towel.
    And as always, your mileage may vary.
    Feel free to critique or criticize, I don’t really care. I’m changing mine every 5000 because that’s what I want to do.
  9. Mar 2, 2026 at 1:35 PM
    #69
    Archer
    Archer New Member
    2025 Ice Cap 4 Runner TRD Pro
    Wow, I've changed mine at 1K, 5K, and 10K and none of those times was it even close to that dark. I did see where someone else got grit out at their 1K but that seems excessive. JMHO
    ToyotaDude99 likes this.
  10. Mar 2, 2026 at 2:19 PM
    #70
    FourBelugas
    23 white ORP
    I wonder if the first 1500 mile change is particularly bad due to the vehicle idling at the assembly plant, at the port, on ship, at the US port, and the stops between there and the dealership.
    Perhaps Toyota has engineered with that in mind but having that bottom oil sanding and grinding away for another 8500 miles before first oil change, yikes!
  11. Mar 2, 2026 at 5:28 PM
    #71
    I bet the first oil drain was so dark because the factory Toyota oil is much darker right out of the bottle.
  12. Mar 3, 2026 at 9:09 AM
    #72
    Color isn't a great metric, just do it at the interval you like or if we want to start comparing potential "reliability" or overall quality, it would be better to get some hard data.
  13. Mar 3, 2026 at 11:13 AM
    #73
    4Hopper
    4Hopper New Member
    24 Ice Cap 4R TRDOR Prem
    Deliberating over a vehicle’s longterm reliability by examining oil color is about as scientific as sniffing the exhaust. Or your own farts.
    Here’s an alternative plan for any current or potential Gen6 owner: Spare yourself the stress of collecting oil swabs, and don’t waste your money on oil diagnosis. Instead, just drive 250k carefree miles at the 10k mi intervals that Toyota’s own engineers recommend. Then if you’d like, go ahead and report back here what color your oil is.
  14. Mar 3, 2026 at 12:15 PM
    #74
    Old Geezer
    Central Indiana
    2025 Hybrid, Red
    There's been times in years past that sniffing the exhaust could tell you something...like if the carb was set too rich or even today, its easy to smell anti-freeze burning in the exhaust (bad head gasket) so just because you don't think that disgustingly dirty oil can be problematic...well, sniff away at your farts.
    Oil doesn't get that filthy own its own. Being concerned about an engine that obviously deposits some type of material into the oil or maybe is burning it should raise some type of flag to anyone with automotive engine experience. Observing and caring for your car is an issue to others. To others, the ostrich approach (AKA, an engineer said so) works best for them.
    And trust me, I am a retired engineer and know a lot of them have basically no common sense. So, if you think that 10K is best because some engineer says so, you are apparently oblivious to the problems with the GM AFM engine destroyers called engineers that thought that turning off 4 out of 8 cylinders by moving a camshaft back and forth is a good idea. Or maybe the radiator and heater coil eating DexCool antifreeze that GM engineers claimed wouldn't need changed for at least 5 years. Well, they said, just don't expose it to air and you'll be ok. Most automotive engineers wouldn't design cars with windshield wipers unless someone above them told them that customers might drive the car in the rain. Most of the recalls in the automotive industry are caused by some engineer that F-d up.
    Personally I don't care if someone does 20K miles or more between oil changes. I just know that I have NEVER seen oil get that dirty that quickly and understand that there is a reason behind it, somewhere. And no, I don't believe that Toy puts in dark colored oil at the factory.
  15. Mar 3, 2026 at 12:16 PM
    #75
    I think I see the face of Jesus.
  16. Mar 3, 2026 at 12:49 PM
    #76
    Have you ever seen the oil that comes out of a diesel engine? It’s jet black and those engines last a very long time.
    ToyotaDude99, icebear and 2Toys like this.
  17. Mar 3, 2026 at 1:09 PM
    #77
    Old Geezer
    Central Indiana
    2025 Hybrid, Red
    I will have to check my forerunner to see if it has a diesel engine in it. that could explain a lot of things.
    ToyotaDude99, Shredder and nimby like this.
  18. Mar 3, 2026 at 1:09 PM
    #78
    Old Geezer
    Central Indiana
    2025 Hybrid, Red
    I was thinking Rorschach test.
    ToyotaDude99 and nimby[QUOTED] like this.
  19. Mar 3, 2026 at 1:48 PM
    #79
    7Runner
    7Runner Forum Loiterer
    2018 Silver SR5P
    I'm going with Groucho Marx.
  20. Mar 3, 2026 at 7:37 PM
    #80
    I’ve read (and also noticed in a DI Kia I previously owned) that direct injection actually does produce more soot than port injected engines. I recall a couple of years ago I was reading that solid particulates (soot) in DI engines were “next” in being the target of environmental controls (can you imagine DEF systems in gasoline engines lol?).
    I’d imagine that every DI design may act a little different. My Kia was sooty, but my NA V6 highlander with the DS port/direct injection design is not sooty. The new toyota 4cyl turbo I believe is a DS design, but being a turbo may make the exhaust look different than NA counterparts. Have you checked your exhaust tip or body work near the exhaust for soot? I specifically remember my Kia having way more soot staining than I ever experienced in a car previously. That Kia would also make the oil extremely dark very quickly.
    Regarding the toyota oil being darker, I can only say that I recall being able to clearly read the dipstick oil level on my two last 0w-20 toyotas when the cars were brand spanking new, and after the first oil change with Mobil 1, it was nearly invisible unless I caught a strong glint of light reflected off the oil/dipstick.
  21. Mar 3, 2026 at 7:42 PM
    #81
    FourBelugas
    23 white ORP
    Gasoline particulate filters have been in the works since early days of the last administration. I know several ford eco boost models have them starting this year. CARB states will insist on it regardless of what the current epa says.
  22. Mar 3, 2026 at 7:58 PM
    #82
    Yeah, in terms of efficiency/pollution benefits, I kinda think that DI is just past the edge of diminishing returns. It adds complication, doesn’t allow the engine to keep it’s own valves clean, and the soot itself has more immediate and direct health effects for people (especially for those around dense traffic, or living near dense traffic) compared to the marginally reduced carbon that comes from any extra efficiency of a DI engine.
    Turbos don’t help with that either, from my understanding.
  23. Mar 3, 2026 at 9:41 PM
    #83
    FourBelugas
    23 white ORP
    It's ironic because the last of the econo sh!t-box, the 2025 nissan versa, uses an ancient 4 cylinder engine that still passes the emissions standards as of 2025MY but without DI and other measures, its 32/40 city/highway mpg wasn't gonna cut it for the ~2030 round of new standards, so Nissan in part made the decision to kill it back in 2024 and made 2025 the last year for the US market. It was not worth the effort to continue the model altogether. So there goes that last ~2500 lb NA Port injection economy car with a 5 speed manual option for the US market.
    The game is rigged against small, light, simple cars. Simple as that. I have one and sure, it is no Miata, but it is more fun to drive and way simpler than, say, the current corolla.
    ToyotaDude99 and ualfltdispatch like this.
  24. Mar 4, 2026 at 2:47 AM
    #84
    That's the ticket, YOU paid for it, so I would think YOU can do what YOU want to do with it!
    ToyotaDude99, robert18452 and 2Toys like this.
  25. Mar 15, 2026 at 10:43 AM
    #85
    RusPro17
    RusPro17 Back home again!!
    Don
    Pa.
    2023 TRD Pro Solar Octane
    SCS wheels and Westcott lift
    Yeah I agree with the difference with the 4 turbo and V6. I use both Amsoil in my wife’s 25 Acura RDX and in my 23 Pro. Her car is black around the same mileage and mine still looks like it was just done. WOW.
    ToyotaDude99 and robert18452 like this.
  26. Apr 19, 2026 at 5:47 PM
    #86
    eightyzips
    eightyzips New Member
    If you or anyone suspects an actual problem with their oil I recommend using blackstone labs analysis service.. no point in trying to guess what the color means and why it tastes like so and so.. Just let the experts run the tests and you’ll know if there is an issue with the oil when you get the results
  27. May 7, 2026 at 11:31 AM
    #87
    jharkin
    jharkin New Member
    Jeremy
    Boston suburbs
    2023 Black Pro
    OP: Did you send that oil to Blackstone for analysis?
    The color of the drained oil is meaningless. It could be purple but if it tests in range for additives and wear minerals you dont have a problem. You are throwing money at a problem that only exists in your imagination.
  28. May 8, 2026 at 12:12 PM
    #88
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    Color is meaningless? Wouldn't you rather have clean new looking oil at 5k or one that looks like black ink sludge. lol
    Of course color of oil has meaning, but it may not be that important depending on a few factors (Oil type, high milage, V-Tech, Turbo...). But like you said most oil tests well even when dark in color, but having dark colored oil is a sign its dirty.
    Old Geezer[OP] likes this.
  29. May 8, 2026 at 1:47 PM
    #89
    jharkin did not elaborate on every possible exception or factor in their post because then we'd be here all day splitting hairs.
    The unwritten, context in that statement is that for the purposes of comparing quality of an engine, engine oil, the suitability of an oil change interval, etc; attempting to make judgements on an engine/oil/interval based on what shade of brown came out is an exercise in futility.
    Obviously if the T-1000 came out of my drain plug I would be concerned but that is beyond the scope of this thread.
    Ripper238[QUOTED] and Toy4X4 like this.
  30. May 9, 2026 at 2:46 AM
    #90
    The color of freshly changed oil in the Mack dump truck I drive is pure black after 2 hours of driving. It's comparing apples to oranges of course and I like to see oil that is somewhat clear on my personal vehicles, but if an oil is completely 'clean looking' when you change it, it brings up other concerns if it's working.. cleaning, lubricating and cooling.
    Ripper238[QUOTED] likes this.
