5vz-fe Rebuild
Discussion in '3rd Gen 4Runners (1996-2002)' started by RoddyRich, Sep 1, 2024.
  1. Sep 1, 2024 at 7:22 AM
    RoddyRich
    RoddyRich [OP] New Member
    97 4runner Limited
    Looking to rebuild the engine I have. Only has 180k miles on it and has a misfire. Not sure on the exact cause of the misfire, but I would like to rebuild the engine for longevity. Decently new to mechanical work.
    Was wondering what all parts you recommend I replace? For rebuild and for convenience sake.
    Any tips and tricks would also be helpful.
  2. Sep 1, 2024 at 7:43 AM
    BLKNBLU
    BLKNBLU New Member
    2019 Nautical Blue OR
    I would work out the misfire first
  3. Sep 1, 2024 at 7:24 PM
    that'smy4runner
    that'smy4runner New Member
    Pull the codes, fix it and keep driving. It doesn't need a rebuild unless its been abused. Go to a junkyard and get an engine to rebuild.
    Toy4X4 likes this.
  4. Sep 2, 2024 at 5:38 AM
    RoddyRich
    97 4runner Limited
    yea thats the plan to rebuild junkyard engine. I have low faith in the people I brought it from, definetely has seen better days
  5. Sep 2, 2024 at 8:03 PM
    Son, slow your roll.
    FIRST. Do a compression (wet and dry) test. Do a leak down test. Do an exhaust gas coolant test. These are CHEAP.
    Compression test will tell you if the cylinders and rings are good. Leak down test will tell you if the valves are good. Coolant test will tell you if you have a bad head gasket.
    If those numbers are all healthy, you will NOT be able to rebuild a better engine. You already may have a really good fairly low mileage engine. These engines were engineered for 500k miles before a rebuild is needed. You are NOT EVEN CLOSE to that.
    If the numbers are off, it should tell you whether you have a bad head or bad head gasket, or worn rings, etc.
    Otherwise, you can then focus on the misfire and chase a bad injector or coil or plugs or whatever. Which you will most likely have to do anyways after dropping in a rebuilt engine.
  6. Sep 3, 2024 at 1:10 AM
    RoddyRich
    97 4runner Limited
    compression test was done. All pressures were in the green but were all off by over 30 psi. I have not done a leak down test yet. And head gasket was replaced by the previous owner who i do not trust to have done a decent job so that needs to be replaced regardless. I am not sure if they did anything else to the engine while they were in there. Since I’ll have to really get in there anyway I would rather it be a big job one time and go all the way
  7. Sep 3, 2024 at 3:13 AM
    Welcome from Wisconsin!
