5th Gen's spotted next to you
Discussion in '5th Gen 4Runners (2010-2024)' started by djwantke, Feb 25, 2024.
  1. Jan 21, 2026 at 3:10 PM
    #91
    djwantke [OP] New Member
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    two gorgeous 5th gens parked with me.
  2. Jan 21, 2026 at 3:10 PM
    #92
    flock together :thumbsup:
  3. Jan 22, 2026 at 12:43 PM
    #93
    94hokie
    94hokie New Member
    23 TRD ORP Lunar Rock
    Hit the grocery store for supplies (beer) ahead of this weekend's ice storm and came out to find a 5th gen parked next to me. Not sure how he got that lift in while still running factory UCA's, but it looked good.
  4. Jan 24, 2026 at 8:27 PM
    #94
    2Toys
    2Toys Imperial Star Cruiser
    Gordon
    2019 4Runner TRDORP
    Outside Boise, Idaho at Lucky Peak Lake.
    AmericanGI and ToyotaDude99 like this.
  5. Jan 30, 2026 at 11:08 AM
    #95
    94hokie
    94hokie New Member
    Stopped by a local shop I actually found on our fine forum here (TEQ Vehicle Outfitters) and they had this bad boy parked out front.
  6. Jan 30, 2026 at 11:17 AM
    #96
    Borracho Loco New Member
    This is something that I hate seeing on trucks/suv's:
    Skinny/Low profile style tires with aggressive tread on a lifted vehicle. To me that screams "Bro". Its rare that I see that setup on 4Runners. The douchebags that have them are usually rolling around around town "Rolling Coal" in their Ford/RAM/Chevy HD series truck. It's always a cartoonish lift with a drop hitch (as if they're actually towing).
  7. Jan 30, 2026 at 5:00 PM
    #97
    He had to get that aggressive VaporCut closer to the ground!
    I mean, why else would would he set it up like that?
    :llama:
  8. Jan 31, 2026 at 9:49 AM
    #98
    22 ORP
    In my neighborhood there is like a 10:1 ratio of 4Runners to Starbucks. I’ll see a dozen on any outing. But yesterday I actually got a thumbs up from another 4Runner driver. After 4 years driving a 4Runner I got an acknowledgment from another 4Runner owner. His vehicle was a 4th gen in Imperial Jade green. Maybe I was getting the thumbs up because our 4Runners were both green. Anyway, I was gobsmacked.
    NB4x4, glwood54, 2Toys and 4 others like this.
  9. Feb 10, 2026 at 3:44 PM
    #99
    22 ORP
    Oh man was I wrong. Since I wrote the reply above I have been purposely looking for 4Runners in my area. I guess I have been assuming that for every 4Runner I happened to see there must be many that I didn’t. Wrong! I must have been seeing all of them. Keeping a rough tally of some other types of 4X4s as well. In order of frequency:
    • Wranglers
    • G-Wagens
    • Broncos
    • Xterras (yeah, more old Xterras than 4Runners of any age!)
    • Defenders
    • FJ Cruisers
    • 4Runners (all generations)
    Congratulations folks. The vehicles we drive are rare!
    AmericanGI, Saker and ToyotaDude99 like this.
  10. Feb 17, 2026 at 8:08 PM
    #100
    great condition FJ (2011-2014?)
    NB4x4, Saker, LCJ77 and 1 other person like this.
  11. Feb 18, 2026 at 6:59 AM
    #101
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    2023 TRD Pro Ice Cap
    Had 2 a 2008 & 2012 wish they still made them!!!:mad:
  12. Feb 18, 2026 at 8:44 PM
    #102
    that’s awesome
    where’d they go!?
    NB4x4 and ToyotaDude99 like this.
  13. Feb 18, 2026 at 8:51 PM
    #103
    Last ones sold in the USA were 2014 Heritage model IIRC.
    After that sales went overseas, don't know how long though.
    Photo of my 2013 Trail Team Edition.
    djwantke[OP], NB4x4 and LCJ77 like this.
  14. Feb 19, 2026 at 6:12 AM
    #104
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    Traded to 2 different dealers 1st was for Tacoma TRD Sport ,Meh, 2nd for 1st 2018 4R TRD OR.
    djwantke[QUOTED][OP] and NB4x4 like this.
  15. Feb 19, 2026 at 11:37 AM
    #105
    v4lkyᚱie
    v4lkyᚱie My ride to Valhalla ᛉ
    2014 white 4ᚱunner
    ᛉ • Rough Country front bumper ᛉ • Reindeer hidden winch ᛉ • Flowmaster cat-back 717972 ᛉ • 3" Rough Country lift ᛉ • RockTrix RT116 17x9, -12mm offset rims ᛉ • Diode Dynamics blue LED lighting
    Had a 6th Gen park next to me the other day. The cringe I crunged lol
  16. Feb 19, 2026 at 11:43 AM
    #106
    Imdav2u
    23 TRD PRO
    Great looking rig, I really like the blue.
  17. Feb 19, 2026 at 11:53 AM
    #107
    v4lkyᚱie
    2014 white 4ᚱunner
    Thank you! I have always wanted a white vehicle with blue accents, I personally think it's a classy look. I just always thought maybe that vehicle would be something a bit... well, more like a Mustang?? LOL. Oh well, someday I'll have my dream sporty car :p
  18. Feb 19, 2026 at 12:06 PM
    #108
    v4lkyᚱie
    2014 white 4ᚱunner
    Wait! I just found this. Silver Lake, Michigan, Sept 2023.
    AmericanGI likes this.
  19. Feb 19, 2026 at 12:35 PM
    #109
    JSP127
    JSP127 New Member
    Found a twin
    AmericanGI, v4lkyᚱie and LCJ77 like this.
  20. Feb 19, 2026 at 1:19 PM
    #110
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    The NERVE of some People(As Bugs Bunny Wouls say that), Eh!?!?!:p
    v4lkyᚱie[QUOTED] likes this.
  21. Feb 19, 2026 at 1:22 PM
    #111
    Aww, you're both little ladder twins!
    JSP127[QUOTED] and Imdav2u like this.
  22. Feb 19, 2026 at 1:23 PM
    #112
    Imdav2u
    23 TRD PRO
    I wanted a Corvette when I was younger, until I realized who drove them. I'm extremely happy with my 4runner.
  23. Feb 19, 2026 at 1:25 PM
    #113
    Imdav2u
    23 TRD PRO
    I always think that ladders give douche bags easy access to your roof to fugg things up.
  24. Feb 19, 2026 at 2:06 PM
    #114
    22 ORP
    Haha. Any douchebag worth his vinegar won’t be dissuaded by the lack of a ladder.
    AmericanGI and Imdav2u[QUOTED] like this.
  25. Mar 19, 2026 at 5:45 PM
    #115
    slick, rare white PRO in my region
    beautiful Limited 4th gen this morn
    Jeep Cherokee this afternoon
    Home Deeps forklift :laugh:
    AmericanGI and 2Toys like this.
  26. Mar 25, 2026 at 3:23 PM
    #116
    6G white trailhunter :eek:
    new limited sequoia
  27. Mar 25, 2026 at 5:50 PM
    #117
    oh wow
    sick taco
    DocSR5, AmericanGI and 94hokie like this.
  28. Apr 3, 2026 at 6:25 PM
    #118
    aw yeah
    this old girl at Canadian Tire yesterday
    not 5th gen 4R’s sorry, worth the share.
  29. Apr 7, 2026 at 7:05 PM
    #119
    rad prefacelift 5th g parked nxt to me @ Dollarama
  30. Apr 7, 2026 at 9:04 PM
    #120
    rad Supra in front of me @ donut shop.
