5th gen tires rubbing..
Discussion in '5th Gen 4Runners (2010-2024)' started by ltancredi, Oct 19, 2020.
lift or shave
  1. Lift
    1 vote(s)
    11.1%
  2. shave
    8 vote(s)
    88.9%
  1. Oct 19, 2020 at 2:28 PM
    ltancredi
    ltancredi [OP] New Member
    Lauren
    Oahu
    2016 SR5 4Runner
    bought used already had fog light, led lights, side mirror/ blinker camera ,front camera,
    so I bought my runner preowned recently and the previous owner changed the tires and they look good but when you turn the wheel all the way it rubs on the front bumper.. just wondering if I should have it shaved down or if I did like a 3 inch lift if that would help? 8A8AB926-ACC9-4CC0-934E-E7EC0AE75105_1_201_a.jpg FACD510D-B9F8-42C3-9E8E-993496BABA01.jpg5BD47FAB-A871-4C3D-8531-9CDC769CA437.jpg
    2Toys likes this.
  2. Oct 19, 2020 at 2:34 PM
    Mtbpsych
    Mtbpsych New Member
    How much rubbing? A lot? Or minor? If it’s a minimal amount of just push the fender liner forward and maybe trim a little bit off the bumper. Cheapest route unless you’re thinking of a lift.
  3. Oct 19, 2020 at 2:43 PM
    ltancredi
    Lauren
    Oahu
    2016 SR5 4Runner
    just a little bit of rubbing and only when its turned all the way .. im a little worried to let someone shave it and mess it up lol plus im kinda looking for an excuse to lift it BUT its expensive and not really needed I guess
  4. Oct 19, 2020 at 2:47 PM
    ltancredi
    Lauren
    Oahu
    2016 SR5 4Runner
    mostly when reversing but my wife drives it sometimes and apparently doesn't know how to reverse with a bigger car so she just turns the wheel all the way and lets it rub... it hurts my soul
  5. Oct 19, 2020 at 2:55 PM
    Mtbpsych
    Mtbpsych New Member
    You can shave some of the bumper with a cheap harbor freight dremel. Just create a line with some masking tape!
    ltancredi[OP] likes this.
  6. Oct 19, 2020 at 3:12 PM
    Shave. It looks pretty close to 3" lift already I don't think that will solve the problem.
    Just blue tape your cut line and make sure both sides look even and cut away. Did mine myself and kicking my self for not doing it earlier.
    Thatbassguy and ltancredi[OP] like this.
  7. Oct 19, 2020 at 3:12 PM
    Mtbpsych
    Mtbpsych New Member
    Looks like he’s stock.
  8. Oct 19, 2020 at 3:17 PM
    Maybe it just looks like a lot of gap in the front.
  9. Oct 19, 2020 at 3:54 PM
    ltancredi
    Lauren
    Oahu
    2016 SR5 4Runner
    "she" lol anyways im not even sure I was told the trd is a little higher then most runners so it wasnt lifted but a lot of people tell me it looks like it is a little bit so idk lol I don't think it is tho
    7385 likes this.
  10. Oct 19, 2020 at 3:55 PM
    ThePnsh3r
    ThePnsh3r New Member
    2020 TRDOP
    Something is off - those wheel gaps make no sense for a stock suspension.
  11. Oct 19, 2020 at 3:56 PM
    ThePnsh3r
    2020 TRDOP
    Also that passenger wheel liner is already torn up pretty badly.
  12. Oct 19, 2020 at 4:01 PM
    ForRun
    ForRun 4Runner
    2020 orp
    Marked mine with tape. Lightly scored with razor knife, then cut with razor..pretty easy
    nimby likes this.
  13. Oct 19, 2020 at 4:21 PM
    S4ndb4r
    S4ndb4r New Member
    Steve
    2018 LTD
    TBD
    What size tires are they? Any chance you’re running wheel adapters?
  14. Oct 19, 2020 at 5:28 PM
    SHAVE!
    Looks lifted already. Bumper cut is cheap and easy.
    Welcome to the forum!
    ltancredi[OP] and 7385 like this.
  15. Oct 19, 2020 at 6:44 PM
    4Runner170V
    4Runner170V New Member
    Tony
    Los Angeles
    2014 4Runner Trail
    It looks like leveling kit. All you have to do is push front fender about 1" and make new hole to secure. then trim/shave front bumper bottom section about same so it will clear. just need drill and knife.
  16. Oct 19, 2020 at 6:55 PM
    You need to do the fender liner mod. A lift won't help you.
    Looks like someone else has already cut up the fender liner in spots trying to alleviate the rub, but they didn't do it correctly.
    This should walk you through it. It's super easy. Instead of using a dremmel to trim the fender slightly, I used a box cutter. You also don't need any pry tools like the article says.
    https://trail4runner.com/2019/07/14/fender-liner-push-back-trimming-on-4runner/
  17. Oct 19, 2020 at 10:39 PM
    LA260
    LA260 New Member
    Had to cut the bumper on mine too after getting the tires installed last Friday. Took 5 mins. Not a big deal. IMG_20201019_220521630.jpg
  18. Oct 20, 2020 at 2:15 AM
    ltancredi
    Lauren
    Oahu
    2016 SR5 4Runner
    ya someone told me the same that looks like someone tried to trim it down already I would rather have someone do it then do it myself just bc I don't trust myself but im also scared to let someone do it and mess it up ..
  19. Oct 20, 2020 at 2:18 AM
    ltancredi
    Lauren
    Oahu
    2016 SR5 4Runner
    honestly im not even sure everyone tells me it looks lifted but then someone else said its not the TRD is just higher then most 4runners so I mean idk im pretty clueless when it comes to cars which is why im hesitant taking it somewhere and they see how clueless I am and start telling me I need to do all this expensive unnecessary stuff to it lol
  20. Oct 20, 2020 at 3:46 AM
    ThePnsh3r
    2020 TRDOP
    Can you turn your wheel to one side and take a picture? Like this
    2Toys and Thatbassguy like this.
  21. Oct 20, 2020 at 10:49 AM
    Wcslv
    Wcslv New Member
    19 TRD PRO
    What model do you have? TRD PRO, TRD OFFROAD, or TRD Offroad Premium. And what size are the tires?
  22. Oct 20, 2020 at 11:53 AM
    newlife
    Knoxville TN
    2021 venture 22 JTR
    All of them.
    Shave the front. Practically free. I used and angle grinder and took maybe 30 seconds a side. I didn’t cut I literally put the side of the disc. Against the bumper and let it shave off keeping the angle grinder moving the whole time back and forth to follow the body lines. Climbing underneath after I was done and used my razor sharp knife to clean up any excess plastic and you honestly can’t tell except there’s no paint on the very edge of that section. Which my truck is black anyways so you’d really be looking to see it.
  23. Oct 20, 2020 at 11:57 AM
    Unless they spent money to put seat covers on leather I'm guessing its a TRD OR. 100% not a Pro look at the front end so it doesn't have the extra height stock.
    Looks like a hood scoop hard to tell.
    And looking again it has some sort of lift for sure prolly a small spacer.
  24. Oct 20, 2020 at 1:42 PM
    ltancredi
    Lauren
    Oahu
    2016 SR5 4Runner
  25. Oct 20, 2020 at 1:43 PM
    ltancredi
    Lauren
    Oahu
    2016 SR5 4Runner
    you know I thought it was a trd bc that's what the guy who did my safety check said but I found the paper in the car from the dealership and it says ... sr5 2wd v6 5a lol
  26. Oct 20, 2020 at 1:47 PM
    ltancredi
    Lauren
    Oahu
    2016 SR5 4Runner
    tire says lt275/70r17. 121/118r im not sure what size that is but that's what's on it ... sorry I told you guys im clueless its my first time having a 4runner other then my old 98 that I had years ago..
  27. Oct 20, 2020 at 1:49 PM
    Looks like you have Bilstein 5100s with a slight lift and tires that are 1 size bigger than stock. :cheers:
    All good. Now you just need to do that fender liner mod.
  28. Oct 20, 2020 at 1:51 PM
    ltancredi
    Lauren
    Oahu
    2016 SR5 4Runner
    is it adjustable if I wanted to go an Inch or two more? and yes ill definitely shave it down or ask someone to help me lol
  29. Oct 20, 2020 at 1:53 PM
    LA260
    LA260 New Member
    So you didn't know that you bought a 2wd 4Runner?
    Mtbpsych and newlife like this.
  30. Oct 20, 2020 at 1:53 PM
    It is adjustable.
    There are settings for the following amount of lift: 0", 0.85", 1.75", 2.5".
    Just a guess, but you might be at the 1.75" mark with yours.
    ltancredi[QUOTED][OP] likes this.
