5th Gen rear whipper blade options
Discussion in '5th Gen 4Runners (2010-2024)' started by MTB4Runner, May 29, 2025 at 6:58 PM.
  1. May 29, 2025 at 6:58 PM
    MTB4Runner
    MTB4Runner [OP] New Member
    Patrick
    '19 4R TRD OR
    Sorry if this is redundant but it didn’t show up on search. what are my best options beyond OEM
  2. May 29, 2025 at 7:23 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
  3. May 29, 2025 at 7:30 PM
    No joke, Oem are pretty good with little hassle, Have not seen any performance decrease with them. Will recommend.
  4. May 30, 2025 at 7:57 AM
  5. May 30, 2025 at 8:03 AM
  6. May 30, 2025 at 8:07 AM
    Nubes
    Nubes Toyota Addict
    If you still have the OEM arm you can get the replacement inserts. PN: 85214-42040
  7. May 30, 2025 at 8:25 AM
    Trico 12L has been OK over the past year. It includes a snap-in peg for ramping onto the window frame in the stowed position.
  8. May 30, 2025 at 9:04 AM
    I’ve always had great results using OEM Toyota wiper refill inserts for my 2014 and now 2021. They always lasted at least 1 year or longer without issues.
  9. May 30, 2025 at 10:02 AM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    Damn. Beat me to it. I was going somewhere similar...
  10. May 30, 2025 at 11:49 AM
    :p
  11. May 30, 2025 at 1:33 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    You got me, my brain must of glossed over rear whipper.
  12. May 30, 2025 at 1:50 PM
    Did someone call me?
    catbrown357, 3JOH22A and Saker like this.
  13. May 30, 2025 at 2:14 PM
    I made the idiot mistake of throwing my OE arms in the trash. But after getting frustrated with the expense and performance of aftermarket wipers, I ended up buying new OE arms again so I could go back to the factory rubber inserts.
    It seems like all the aftermarket options are pure marketing. They’re way more expensive than OE, wear out sooner, and never quite operate as smoothly/nicely.
    icebear and Saker like this.
  14. May 30, 2025 at 2:41 PM
    Well, meet a fellow idiot. I did the same thing some time back. I finally got fed up with trying to guess each time I need wiper blades which ones are going to not only work, but last past 6 months. Today I just ordered new oem blade assemblies/inserts that you can swap out the inserts on next time around.
    Saker and McSpazatron[QUOTED] like this.
  15. May 30, 2025 at 3:01 PM
    I’m glad I hung onto the previous arm.
    The wiper on there didn’t wipe the inside arc completely, the Trico rear I replaced it with switched to not wiping the bottom properly and made a louder clunk when retracting.
    Put the old arm back — that I assume is original — with a new rubber wiper from the dealer and it’s now working well.
    Saker likes this.
  16. May 30, 2025 at 3:06 PM
    Ironically, the cost to undo my mistake and buy new OE wipers frames and rubber inserts cost a bit more than getting fancy aftermarket wipers. Could have been worse.
    Now the only thing I need to do is convince my nearest Toyota parts dept to carry inserts. They’ve told me Toyota “stopped making rubber refills” on a couple occasions. Last time they gave me that line, I corrected him and told him that’s not the case, and politely requested they start stocking them as a service to their customers. I’m sure that will convince them to stock it lol:rolleyes:
    Last time I ordered inserts I went through toyota online and could only have them shipped to a dealer an hour away.
    Saker likes this.
  17. May 30, 2025 at 3:14 PM
    I bought Michelins for the Corrola S about five years ago. Still good.
    Ripper238 likes this.
  18. May 30, 2025 at 4:05 PM
    eurowner
    eurowner New Member
    Scoty
    Depends on how fast you are going in reverse.
  19. Jun 1, 2025 at 3:10 PM
    kojak
    kojak New Member
    21 SR5P 4x4
    I have replacement inserts but it still sucks once it collects some dirt. The front is fine but I have to use gas station swamp water if I want to actually see out the back.
  20. Jun 2, 2025 at 8:20 PM
    Reverse is just slightly taller than 1st gear, so ~40 mph at redline :rofl:
  21. Jun 3, 2025 at 2:31 PM
    You can also roll down the window in a worst case retreat situation lol
  22. Jun 3, 2025 at 2:53 PM
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    I cant find Toyota inserts for the front so i went the Bosh blades which are fine. The rear has no insert option at Toyota so you have to buy the whole thing.
  23. Jun 3, 2025 at 4:27 PM
    eurowner
    eurowner New Member
    Scoty
    The reverse camera shuts off at 35mph, I bet!
  24. Jun 3, 2025 at 4:33 PM
    eurowner
    eurowner New Member
    Scoty
    85214-0E140 Windshield Wiper Blade Refill
    85214-06140 Rubber, Wiper, Left Refil
    Uh,
    85242-35050 Back Glass Wiper Blade
    85214-42040 Rubber, Rear Wiper
    Captain Spalding likes this.
  25. Jun 3, 2025 at 4:55 PM
    Rain ex that mutha out as much as you can.
  26. Jun 3, 2025 at 4:59 PM
    I used to spend hours hand applying a perfect coat of rainx way back in the day. Nowadays, the windshield washer fluid they make is really just as good. Once it starts raining, a few short bursts of the washer fluid and then the water just rolls off just like a fresh coat of rainx!
  27. Jun 3, 2025 at 5:02 PM
    So one should buy nine of 85214-42040 and zip tie them together to make トヨタ純正 rear whipper
    eurowner[QUOTED] likes this.
  28. Jun 4, 2025 at 4:53 AM
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    Toyota makes the best wipers. If you have your factory blades, you can still get Japanese made inserts for $5 each. Mine had aftermarket wipers and would not work. I got Japanese blades from ToyotaPartsDeal.com for $22 each front and $5 insert for the rear. Always save your old parts.
  29. Jun 4, 2025 at 5:30 AM
    If it matches the behavior of the Tundra and Tacoma, then the camera won't shut off above a certain speed. In fact, you can put the lever into reverse while driving forward at highway speeds. The ECM doesn't physically shift the transmission into reverse, but the camera and reverse lights will activate.
  30. Jun 4, 2025 at 6:28 AM
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    They have some strange safety things built in. My hatch didn't shut completely and when I would occasionally hit a bump, hazard lights and dash lights and a tone would come on, then go off. I guess they are worried about something falling out the back, especially kids. I wish they would mention these things in the manual instead of see dealer.
