5th Gen rear suspension question?!
Discussion in 'Suspension' started by Hitch, Oct 23, 2021.
  1. Oct 23, 2021 at 9:26 AM
    Hitch
    Hitch [OP] New Member
    Hello! Currently I have Bilstein 6112s, Bilstein 5160s and rear spring spacers installed. I have a decent amount of weight in the cargo area whether it's hunting gear, break down/recovery equipment or towing a smaller trailer. I can't deal with the stance and sagging rear end. What would you ladies and gents suggest to fix that?! A friend recommended Timbren but not sure if thats the way to go. Thanks in advance!
    -Hitch
  2. Oct 23, 2021 at 9:30 AM
    Doglover2003
    Doglover2003 New Member
    '18 ORP w/KDSS
    You need rear springs, spacers not going to cut it. Dobinson, Eibach, OMe, etc... make good stuff for weighted down 4runners. I have Dobinsons rear springs for constant 600-800 lbs for my 4runner.
    Hitch[OP] and Toy4X4 like this.
  3. Oct 23, 2021 at 9:32 AM
    Doglover2003
    '18 ORP w/KDSS
    Ironman4x4 also makes legit stuff for our trucks from Australia.
    Hitch[OP] likes this.
  4. Oct 23, 2021 at 10:21 AM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    #1...What's the least amount of weight you'll typically be carrying?
    #2...Most weight without trailer? A real number within 50 pounds or so, not a
    guesstimate.
    #3... Same question for anticipated vehicle load, plus trailer tongue weight.
    While that may sound a little OCD, it's not. I assure you.
    Once you know those criteria finding something that works doesn't get any easier, but you'll know what won't work. jm2c
  5. Oct 27, 2021 at 6:50 AM
    Hitch
    Totally understand, thank you. But what do you recommend; springs, airbags, Timbren?
  6. Oct 27, 2021 at 6:56 AM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    Personally, my decision was to go with air bags (Firestone Ride-Rite model #4135). A pair will handle varying loads up to 1,000 pounds, with a maximum air pressure of 35psi(adjust psi according to weight -obviously). Unloaded they need to be kept at 5psi minimum.
    https://www.firestoneip.com/kit-search/
    Can be ordered > a m a z o n.
    SlvrSlug and Hitch[QUOTED][OP] like this.
