5th gen Low cost 2/1” lift setup
Discussion in 'Suspension' started by Gravel, Feb 16, 2026.
  1. Feb 16, 2026 at 7:25 PM
    Gravel
    Gravel [OP] New Member
    SR5 4x4
    Our new (to us) 2022 SR5 is great, but I didn’t like the stock stance. I’m planning on a Bilstein 6112/5100 or better setup sometime in the next year, but I didn’t want to wait to get it up off its belly. So I started looking for a good, safe, low budget lift setup.
    So far I’ve spent less than $300 on a 2/1” lift, including new front sumo style bump stops. A Cornfed 2/1” spacer kit was $200, shipped. The bump stops were $58 shipped. I’ve got a set of rear sumo style stops on the way, add another $65, they’ll be here in a few more days, but I don’t think they’ll be as important to the ride as the front.
    The Cornfed install video is great, shows the work step by step. I watched it several times. The installation, including the front bumpers, took right at 2 1/2 hours.
    The ride and handling are as good or better than stock. It still has a bit of the stock wallowing, but the sumo stops are a big improvement in adding control over bumps/dips. It’s still stable, cornering is still good, considering the price it’s a great setup!
    For the lift spacers, I went to https://www.4runners.com/threads/cornfed-suspension-lift-leveling-kits.33722/ His service is great!
    The front bump stops: https://www.ebay.com/itm/389617179259
    Rear bump stops: https://www.ebay.com/itm/389538196850
    Edit for clarity: The 285s and Spidertrak wheel spacers might not clear on a stock car. I trimmed the front of the fenders and did a body mount cut/plate before adding the suspension, wheel spacers and tires. There’s still some trimming left to do if needed on the front fenders, but so far nothing has rubbed..
    MeefZah and Gman2530 like this.
  2. Feb 16, 2026 at 7:29 PM
    Gravel
    SR5 4x4
    Here it is, stock wheels with 1 1/4” Spidertrak spacers, 285/70 tires and the low budget suspension!
  3. Feb 16, 2026 at 7:46 PM
    PVT Pablo
    PVT Pablo
    Paul
    Puget Sound, WA
    2016 4Runner TRD Pro, 2023 Tundra Platinum Hybrid
    Those preload/top hat spacers really aren't bad. Way better than just slapping a 2" chunk of metal over the coilover.
    Looks good, don't forget to retorque those wheel spacers!
    When you do eventually move to the 6112/5160 setup you won't be disappointed.
    TrailSpecial22 and Gravel[OP] like this.
  4. Feb 16, 2026 at 7:49 PM
    2019 TRDP w/Kangs brah!
    Save money for what you really want. Doesn’t make sense to buy something you don’t want.
    Gravel[OP], 1SilverRunner and roooo like this.
  5. Feb 16, 2026 at 7:54 PM
    Gravel
    SR5 4x4
    The only parts that I bought that won’t stay for good are the lift spacers, and I’m pretty sure I can get ~ $125 for them used. Not much loss there, and I’ll take the time to learn more about exactly what I want long term.
    But thanks for the advice..
  6. Feb 16, 2026 at 7:58 PM
    Gravel
    SR5 4x4
    I looked at the super cheap top load spacers, not going to use them, ever. Cornfed is a low cost lift done correctly, IMO.
    Already retorqued the spacers once, I’ll do it again next weekend.
  7. Feb 17, 2026 at 8:46 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Mods? Don’t ask… Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS extended travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Diode Dynamics XPR reverse bulbs LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Might want to check for CV and Ball Joint bind at full droop...
    Large front top hat spacers are a bit dangerous since they lower your entire front coilover assembly, increasing droop beyond the factory range.
    A 1" spacer (granting a 2" lift) may be alright but it's certainly pushing it. Max I'd recommend is
    .5" for stock shocks (1" lift)
    or
    .25" for extended travel shocks or the Pro's Fox suspension. (.5" lift)
    You're on the right path with the bump stops but depending on their compressed height you may want to add shims. This will avoid bottoming out the shocks internally before the bump stop is fully compressed.
    My bump stop setup for reference: compensating for .25" top hat spacers over extended travel Dobinson IMS.
    ... Purposefully added spacers to allow for more droop but even with a diff drop the CV boot bind is present. CV's themselves, ball joints, and UCA to spring contact is super close but no binding. I wouldn't generally recommend this setup as it's super close to the limits of the CV's and ball joints. Maxed out mid travel
  8. Feb 17, 2026 at 9:26 AM
    Gravel
    SR5 4x4
    Agree 100% about top load spacer lifts, they extend the strut for all of the lift provided, not good! I see 3” lift top load spacers and cringe!
    My Cornfed 2/1” setup has a 3/8” top load and a 1 1/4” preload spacer, but since you remove the rubber isolator it makes for about 2” of lift. I didn’t measure heights before install, it looks like it might be 2 1/4”-2 1/2” lift..
    With my setup the ball joints look happy and the UCA doesn’t contact the coil spring. It should be safe. That’s why I went with Cornfed, I like the engineering of their design. Maybe others use similar designs, it’s nothing magical, but for a cheapskate lift it’s the only design I’d ever run.
    My rear bump stops are on the way, I’ll post some pictures of the front and rear whenever they’re installed. The fronts have a 1/4-1/2” of space at ride height before they make contact, seems about right..
  9. Feb 17, 2026 at 4:48 PM
    Gravel
    SR5 4x4
    The rear bump stops arrived today, 15 minute install. Jack up and block one side at a time, small impact driver made it easy.
    The photos show the gap at ride height, I think it’s just about right. Haven’t driven it with the rear bumps installed yet, I’ll update this in a day or two.
    Overall, I’m pretty happy with it so far. No decrease in ride or handling from stock and the front bumps made a good difference in bigger bumps/dips. As long as the rear acts similar, I’m calling the suspension done for now.
  10. Feb 23, 2026 at 2:47 PM
    Gravel
    SR5 4x4
    Closing this one out. For the money spent, I’m really happy with the Cornfed spacer lift and the front bump stops. They’re doing great considering it’s a $250 setup. The front bump stops will likely stay on the car permanently, or until they fail. If they fail soon I’ll get a set of real SumoSpring bump stops for the front, even though they’ll double the cost of my suspension, lol!
    The rear bump stops are pretty good, but they have a slightly harsh engagement. Since they were very inexpensive, I experimented with them by drilling a 1/2” hole through the bump stop, along the axis of the axle. This definitely helped, the engagement is smoother now. But since I’ve compromised the structural integrity by drilling through them, I don’t expect them to last very long. Whenever they come apart I’ll get some better stops, maybe the Perry Parts?
    MeefZah likes this.
  11. Feb 23, 2026 at 4:03 PM
    PVT Pablo
    PVT Pablo
    Paul
    Puget Sound, WA
    I've got the Perry Parts. They're pretty awesome for non hydrobumps, and their customer service is awesome.
    Gravel[QUOTED][OP] likes this.
  12. Mar 11, 2026 at 5:54 AM
    Gravel
    SR5 4x4
    After a few weeks and a couple thousand miles of commuting, highway and a little bit of off-road driving I’m really happy with the performance of this setup, considering it was just over $300 in parts. If I did it again, I’d probably skip the rear bump stops and save that money, but the front bump stops are definitely worth doing, they work great. I think the front bumps are the best cost/performance value I’ve ever tried, they give my 75,000 mile stock front struts a really nice, progressive feel that makes bigger bumps very comfortable and controlled. Overall, the car feels better than it did stock, and that’s not common for a super cheap lift setup.
    However.. I’ve been working a fair amount of OT in the last few weeks.. so I’ve got a set of 6112/5100 bilsteins in the garage and 1 1/2” B12 Bilstein rear coils on the way. Still looking at UCAs, whenever the time is right I’ll grab a set. I’m not in a hurry, it might be a month or two before I have a free weekend to install anything.
    Anyone have experience with the $400 UCAs on the market? RSO and Freedom Off Road are about the same price, look virtually identical. Functionally they’re probably the same. Durability is the question..
  13. Mar 11, 2026 at 6:12 AM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    2020 GX460
    TLCA #25089
    Opinions vary on this but for a 2" front lift your best money spent is... staying with the OEM UCAs. Some people will say they couldn't get good alignment without aftermarket, etc; I disagree. Having had a set of Total Chaos UCAs on my first 4R because I was convinced that I "needed" them, and then regretting that decision due to cost, longevity, and maintenance / greasing requirements, I decided to not use aftermarket ones ever again. I'm 4 lifted trucks later after that decision and I've never had an issue with the OEM UCAs.
  14. Mar 11, 2026 at 6:48 AM
    Gravel
    SR5 4x4
    I’m thinking about 2 1/4” - 2 3/4” of lift with the 6112s. I’m barely under caster spec now, maxed out, at slightly less than 2” so I’m thinking I’ll need some UCAs to get it right when it’s a little taller. It drives great now, but a little more stability wouldn’t be a bad thing.
    You make a great point about maintaining UCAs, that’s exactly what I’m trying to avoid. I think I want OEM style rubber bushings and ball joints, and I know I want higher quality to reduce any kind of problems like you described.
    MeefZah likes this.
  15. Mar 14, 2026 at 11:19 AM
    it will be such a difference between the OEM hard rubber ones.
  16. Mar 14, 2026 at 11:23 AM
    im partial to OME or Bilstein UCAs and will get them if/when the OEMs wear out.
  17. Mar 14, 2026 at 11:25 AM
    agreed. My 2011 177k & 2022 58k have 2” front lifts on OEM UCAs and no issues with alignment or durability.
    MeefZah[QUOTED] and Gravel[OP] like this.
  18. Mar 25, 2026 at 2:35 PM
    Guppy1301
    Guppy1301 New Member
    Silver 2019 TRD ORP
    Bilstein 6112/Icon 2" rear TSO bumper 285 MT Baja Boss Northstar x2 Voltage pro booster
    I've been running the 6112's and OME UCA's. Very happy with both. No noise at all.
    Gravel[OP] and TrailSpecial22 like this.
  19. Mar 26, 2026 at 7:11 AM
    Gravel
    SR5 4x4
    Just ordered a set of Dobinsons UCAs. Amazon had a great deal, $657, lowest price by $75. I was looking at Freedom UCAs, at retail they were about half the price of Dobinsons, but the Amazon price was good enough to get my money.
    Might need to find a ball joint press, some of the information mentions they don’t come with the ball joints installed. I’ll find out next week.
    Guppy1301 and TrailSpecial22 like this.
