5th gen 4R ATF Drain and Fill question
Discussion in '5th Gen 4Runners (2010-2024)' started by Chrispchicken9, Nov 24, 2025.
  1. Nov 24, 2025 at 3:26 PM
    Chrispchicken9
    Chrispchicken9 [OP] New Member
    I plan to do an ATF drain and fill on wife’s 2016 4R.
    any concern re-filling through the dip stick instead of the fill plug located on the transmission?
    with the engine off?
    I do this with my ‘04 Tacoma no issues, but the 2016 4R is newer so wasn’t sure.
    thanks in advance
  2. Nov 24, 2025 at 3:35 PM
    dan777
    dan777 New Member
    Dan
    South Jersey
    19 ORP
    Pretty certain you don’t have a transmission dipstick. It’s a “sealed” transmission
    1SilverRunner likes this.
  3. Nov 24, 2025 at 3:40 PM
    Chrispchicken9
    Lol I see now that you are correct..
    Fill plug it is then.
  4. Nov 24, 2025 at 3:48 PM
    kouack
    kouack New Member
    Prov. Of Québec, Canada
    4Runner Limited 2024
    Bone stock
  5. Nov 24, 2025 at 3:55 PM
    dan777
    dan777 New Member
    Dan
    South Jersey
    19 ORP
    When I did mine I ran a tube up to the engine bay and attached a funnel. Much easier than pumping it in from below
  6. Nov 24, 2025 at 4:13 PM
    Chrispchicken9
    Thanks I’m aware of the temperature window to refill.. don’t love the idea of running a jumper in the OBD..
    Honestly just putting the exact same amount of fluid back in than what came out seems low risk.. this is how I’ve always done it lol
    Is the concern mistakenly not putting the right amount back in? Or that fluid potentially leaks resulting in low volume so is they say to do the fluid level drain method. Does seem a little overkill, but understand the transmission is expensive
  7. Nov 24, 2025 at 4:16 PM
    Chrispchicken9
    I’d be more concerned of being on perfectly level ground for this level check as opposed to just putting the same exact volume back in haha
  8. Nov 24, 2025 at 4:17 PM
    dan777
    dan777 New Member
    Dan
    South Jersey
    19 ORP
    In my opinion the biggest downside to this method is that you’re counting on the current level being correct.
    Grug556 and 1SilverRunner like this.
  9. Nov 24, 2025 at 4:20 PM
    Chrispchicken9
    I have the same concern!
  10. Nov 24, 2025 at 4:53 PM
    yeah there is major concern as there is no dipstick for the trans.
  11. Nov 24, 2025 at 4:56 PM
    ^ this and add a 1/2 quart then do your temp check at the port on the trans pan to barely a trickle comes out.
    BS67 likes this.
  12. Nov 24, 2025 at 5:26 PM
    If your transmission is shifting fine before your fluid change and you put the same amount of fluid back in then you shouldn’t have any issues. I’ve done this on a bunch of vehicles and they have been fine.
  13. Nov 26, 2025 at 4:53 PM
    Use an OBD2 dongle to show pan temperature if you don't want to stab a paperclip in the OBD2 port.
    Ground doesn't have to be perfectly level. Most garage floors are fine.
    icebear and TrailSpecial22 like this.
  14. Nov 27, 2025 at 11:25 PM
    If you use the dongle instead of the paper clip method, do you still have to do the shift sequence voodoo before the transmission reaches temperature?
  15. Nov 28, 2025 at 5:57 AM
    ^Not needed. Just watch the trans pan temperature until it's in the range specified in the FSM, then crawl under the transmission and open the check plug.
  16. Nov 28, 2025 at 7:41 AM
    Grug556
    Grug556 New Member
    Kings, Crestone Rack, Baja S8, Baja Fogs, Baja XL80s, Baja mini cubes, SPOD, ARB compressor, RCI full skids, ROAM box and stuff. ST Pros. Shrockworks sliders... GOAT armour
    104-109 seems ok. But if you havent loosened the check plug do it before you get started, just enough to make sure it moves. Mine was semi rusted solid and was a fucker. I am not sure how people use IR gun as when I checked with mine on the pan it was off a few degrees compared to my scanner.
    I miss doing manual transmissions.. cold with just two plugs. So much easier.
  17. Nov 28, 2025 at 9:41 AM
    4onto
    4onto New Member
    Toronto
    2009 SR5 V6 4WD
    It's good that ambient temperatures are cooler now. That 36C to 46C window flashes by quickly in the warm weather. It's good to have a helper call out the temps or flashes while you're already under there, ready to pull and stuff the plug back in. Otherwise, be light on your feet.
