5th Gen 400K+ Club - Thoughts and Experience
Discussion in '5th Gen 4Runners (2010-2024)' started by ChessGuy, Oct 12, 2025.
What range mileage do you have on 5G today?
  1. 0-50K
    24 vote(s)
    37.5%
  2. 50K-100K
    28 vote(s)
    43.8%
  3. 150K-200K
    8 vote(s)
    12.5%
  4. 200K-250K
    2 vote(s)
    3.1%
  5. 250K-300K
    1 vote(s)
    1.6%
  6. 400K+ Going Places
    1 vote(s)
    1.6%
  1. Feb 5, 2026 at 8:01 PM
    #91
    ToyotaDude99
    ToyotaDude99 Obsessed with 4Runners... And anything Toyota
    Earth
    1995 4Runner 3.slow
    Well, I don't need a 200,000 km sticker, but I AM for sure looking at getting one made at the sticker shop in town when mine reaches 400,000 km. Too bad Toyota, I'll do it myself. And the one I get made will still be stuck on there firmly 400,000 km later when I get my 800,000 km sticker made! :yes:
  2. Feb 5, 2026 at 8:07 PM
    #92
    ChessGuy [OP] New Member
    L
    20 Venture/17 Taco
    Oh we know. Ask Pablo @PVT Pablo how many guns he has and he is able to use. Amen.
  3. Feb 5, 2026 at 9:20 PM
    #93
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Hah
    Not all of you know, at all. Too many Americans sh*t on their country constantly, the same country that allows them to be whoever they wanna be, sit on their a** and drink Starbucks, while collecting a cheque of valuable currency, ultimately living more comfortable than anyone person in the history of the earth, it’s silly :p
    And I’m half American, with citizenship.
    Lol Canada has so little guns and such strict storage/transport laws that now they are still saying they are attempting to forcefully buy back guns they deem illegal 5 minutes ago that they already sold law abiding Canadians. That will get police killed it’s insane to attempt.
    Sorry for going off on a tangent op
  4. Feb 5, 2026 at 10:40 PM
    #94
    PVT Pablo
    PVT Pablo
    Paul
    Puget Sound, WA
    2016 4Runner TRD Pro, 2023 Tundra Platinum Hybrid
  5. Feb 5, 2026 at 11:18 PM
    #95
    Greg D
    Greg D TJ312
    TJ312
    2013 4runner
    I'm at 250k on my Limited. I've had to rebuild the front axles. One was an operator error and while fixing that one, I found the passenger side boot leaking a little around the clamp. I probably could have reclamped it on vehicle, but I was there and the Toyota kits were just $46 each. That may be more because of my axles always turning with AWD. I've never had one that early in my 3rd gen. I'm going to have to do valve cover gaskets by 300k. I do radiator hoses around 300k because I can't walk far anymore and easier than on the side of road. I always carry my old serpentine belt and hoses on the road and trail just in case. I'm getting a little oil leak on power steering pump side of the engine around the front cover. Brake cleaner is easier than replacing anything yet. It might be coming from the crank seal and being slung. I researched and read there were a few $10 crank seal issues. It can make it look worse than it is. I change my oil every 10-18k now with a $15 K&N 20k oil filter or once a year. I don't use or drip any oil and this engine keeps oil cleaner much longer than my 3.4. I have always used synthetic oil and lube with no issues. I believe in Mobil 1 5w-30 synthetic because I have lived it already in other Toyotas. I use their 75w90 gear oil in diffs and transfer case. It's good for 500k. Couldn't stay out of the ditch long enough to test that, but I'll be dead before I have to change mine again unless I contaminate it. I used to operate a PC but my engine is getting broken in and revs and responds without the slug/lag now so I don't use it anymore even with my 33s. More miles=better mileage in mine. I would recommend 5w30 synthetic oil whatever brand and synthetic is good for 10k+ depending on the brand. Originally they had 5w30 and I used 0w20 synthetic, but switched to 5w30. I read about a lot of engine problems with thin oil now. Thin oil is just to give you a little more power and mileage, better emissions and it's probably easier to recycle. I don't have a rattle or squeak anywhere, drivers leather seat looks like it go 300k before tearing now. Don't try to overfill your gas tank either. I think that's what started my PO430, PO2443 codes. If you ever replace an ABS/speed sensor, you'll have to use Toyota for it to work as well. Just a few lessons and experiences so far. You'll learn to ask.
    YELDARB, ChessGuy[OP] and djwantke like this.
  6. Feb 5, 2026 at 11:21 PM
    #96
    Greg D
    Greg D TJ312
    TJ312
    2013 4runner
    I believe that.
    ToyotaDude99[QUOTED] likes this.
  7. Feb 5, 2026 at 11:28 PM
    #97
    Greg D
    Greg D TJ312
    TJ312
    2013 4runner
    The new Rav4 Prime hybrid was the second fastest Toyota after the Supra today. I was thinking about the Rav4 V6 just the other day. I bet they were quick. I don't see many today. I know a lady with 550k on about the same year and it's unbelievably clean. It might be a V6. I've been trying to determine if Toyota is using the same body as the same Chevrolet with different front and rear metal or plastic. They did that with the Crown Estate wagon. I look for 4runners to be built in north america one day. I hope they do it in Canada. My best Dodge trucks were built in Canada i thought.
  8. Feb 5, 2026 at 11:40 PM
    #98
    Greg D
    Greg D TJ312
    TJ312
    2013 4runner
    I saw another guy from Canada that had 440km. Canada is so gorgeous. I would have to have a winter and summer 4runner. I like Canada and I don't agree with how they are being treated. They are a strategic neighbor and ally.
    You can get one every 100k just Dropbox a picture of odometer.
    ToyotaDude99 and ChessGuy[OP] like this.
  9. Feb 5, 2026 at 11:40 PM
    #99
    very good read,
    information copied.
  10. Feb 6, 2026 at 4:26 AM
    #100
    L
    20 Venture/17 Taco
    :hattip:
    Great write up and experience. Would you be able to upload a Pic of your rig at 300k?
