5k or 10k oil change. Need your opinion
Discussion in '5th Gen 4Runners (2010-2024)' started by morfdq, Nov 27, 2025.
  1. Nov 27, 2025 at 7:18 PM
    Oh, grasshopper,
    Problem solved with a proximity sensor for that usage tracker!
    icebear[QUOTED] and 2Toys like this.
  2. Nov 27, 2025 at 7:19 PM
    RSG sliders, Yakima Megawarrior basket, Black Rhino wheels, SOS Streamline bumper and skids, Warn VR EVO10S winch, OME MT64, Bilstein rear lift coils, Rigid Dually SS ditch lights, SR light bar, and Diode Dynamics SS3 fogs.
    Haha!
    Happy Thanksgiving!
    Definitely 5K.
    Or, 10K.
    Read the manual. ;)
  3. Nov 28, 2025 at 6:19 AM
    morfdq [OP] New Member
    lol. Thanks buddy. Hope you had a wonderful thanksgiving
    08TXRunner[QUOTED] likes this.
  4. Nov 28, 2025 at 10:48 AM
    Powerstroke
    Powerstroke New Member
    Joe
    Spring Hill, SC
    2023 TRD Off Road Premium
    Is it 5,000 miles for the winter?
    morfdq[OP] likes this.
  5. Nov 28, 2025 at 12:25 PM
    Mach141
    Mach141 New Member
    Just split the difference,.... 7,500 is the absolute perfect time for every driver of every vehicle
  6. Nov 28, 2025 at 12:34 PM
    Tooly
    Tooly New Member
    Okanagan, BC Canada
    My other car, Toyota actual calls for oil changes every 6 months. The last oil change I think I only had about 1600km on that oil lol
    For the 4Runner I change the oil about every 6 months regardless of mileage because it does a lot of short trips which would cause it to fall under the severe service interval.
  7. Nov 28, 2025 at 12:37 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    True. But. I’ve pointed out more than once this puzzling fact: in canada and the states they both say change your oil after 5k…but canada is 5000kms which only equals 3100 miles…and simultaneously yankees are also told change oil after 5000, miles - that’s over 8000kms.
    Make it make sense.
    I think I get it…Canada is robbing us, fooling citizens to change oil after what is in reality only 3100 miles.
  8. Nov 28, 2025 at 12:50 PM
    Mach141
    Mach141 New Member
    But one highway drive of 30+ miles erases all the contaminant build up from all those short trips. So instead of changing the oil, just take a 30 mile Sunday drive occasionally and then change it at 7.5k, ignore the date. I have vehicles that go over 2 years between oil changes
  9. Nov 28, 2025 at 1:02 PM
    Mach141
    Mach141 New Member
    I did a quick google of this. It appears your correct. that is quite ridiculous. I also saw a chart saying if you drive like a regular person, change at 5000 kilometers, but if you fall into the severe duty category, your OCI.....was....wait for it... exactly the same...5000 kilometers
    djwantke[QUOTED] likes this.
  10. Nov 28, 2025 at 1:19 PM
    2Toys
    2Toys Imperial Star Cruiser
    Gordon
    2019 4Runner TRDORP
    Sure felt like I must have done this yesterday!
  11. Nov 28, 2025 at 1:24 PM
    2Toys
    Gordon
    2019 4Runner TRDORP
    I use molasses! No consumption at all between oil changes! Engine's a little noisy tho... :notsure:
    5six[QUOTED] likes this.
  12. Nov 28, 2025 at 1:33 PM
    alittleoff
    alittleoff New Member
    Steve
    406
    '16 TP
    One thing is for sure, no one can or will have an accurate way to measure time against miles traveled.
    Miles is an accurate way to determine the intervals of changing a vehicles oil.
    Time is good for changing your smoke detector batteries and baking banana bread, which I just pulled out of the oven.
  13. Nov 28, 2025 at 1:43 PM
    Photon_Chaser 60,136 smiles and counting…
    West Coast to the Sierra Mountains
    Oil change every Thanksgiving (and dont forget to grease the zerks with Cranberry Sauce)
    5six likes this.
  14. Nov 28, 2025 at 3:03 PM
    Greg D
    Greg D TJ312
    TJ312
    2013 4runner
    I have always done 10k using synthetic Mobil 1 5w-30 and filter every 5k. I would only do that with synthetic. You won't have any engine sludge ever with synthetic. I use high mileage because I am. Synthetic gets darker over time which means it's working. Never had a 4runner use oil. Yet.
  15. Nov 28, 2025 at 3:18 PM
    Powerstroke
    Joe
    Spring Hill, SC
    What if I use 5W-30 weight in the summer? Can I go 10k miles?
  16. Nov 28, 2025 at 3:42 PM
    Beachguy
    2024 TRP ORP
    You can actually wait 30k miles. That’s what the W-30 stands for. Wait 30.
    5six, icebear, Schlappesepple and 2 others like this.
  17. Nov 28, 2025 at 5:31 PM
    That’s funny shit.
    BS67 likes this.
  18. Nov 28, 2025 at 5:38 PM
    The answer is yes. A fake oil change interval thread started as a joke will turn into an actual OCI thread all by itself.
    5six, icebear, BS67 and 2 others like this.
  19. Nov 28, 2025 at 5:50 PM
    #49
    Powerstroke
    Joe
    Spring Hill, SC
    Well it’s winter now so I am good until summer.
  20. Nov 28, 2025 at 9:46 PM
    #50
    NeverTooLate71
    NeverTooLate71 New Member
    Bob
    2024 4Runner SR5
    Same here
    5six likes this.
  21. Nov 29, 2025 at 4:04 AM
    #51
    BS67 likes this.
  22. Nov 29, 2025 at 4:33 PM
    #52
    Curlystooge and alittleoff like this.
  23. Dec 1, 2025 at 6:19 PM
    #53
    5six
    5six New Member
    55_4Runner
    GTA, Ontario, Canada
    2022 Black TRD ORP
    But what about tire pressure? LOL
