5100 on top setting, what to do with the back?
Discussion in 'Suspension' started by trip, Jan 19, 2022.
  1. Jan 19, 2022 at 8:36 AM
    trip
    trip [OP] New Member
    Trip
    2013 Limited, 2022 TRD Pro
    Bailstein Lift
    I have 5100 on the 2.75 setting in the front of my 2013 Limited. The back I have a 1.5 spacer? Not digging it completely. It is not bad. I put Bilsteins in the back so the max i can lift it is 2 inches.
    Anybody have a 2.0 inch Spacer on theirs that I could see what the rack looks like?
  2. Jan 19, 2022 at 8:58 AM
    slixx1320
    slixx1320 New Member
    How much lift did you get at the highest settings? Are you on stock OEM springs?
  3. Jan 19, 2022 at 10:44 AM
    If you put extended travel shocks in back, I would lift with springs. They aren't very expensive, and you can get different spring rated based on your typical use.
    FWIW, I am at 2.3/1.5" so your rake would be similar to this with 2.75/2".
    I used Bilstein b12 springs in the rear.
    619T4R and afret like this.
  4. Jan 19, 2022 at 10:57 AM
    Superdave1.0
    Superdave1.0 New Member
    LX470
    OME or eibach springs in the back will ride better than a large spacer. Then you can add trim packers or small spacers if you need a little more height.
  5. Jan 19, 2022 at 12:57 PM
    ToyotaRDie
    ToyotaRDie New Member
    I have 1.75" in the front and 1.5 spacer in the back and still have rake, which I don't like. I am looking to go up to 2.75/2' to level it out. Would you know how many inches you are from the ground to the fender, in the front and back? I am currently measuring 36.5" in front and 38" in back.
  6. Jan 19, 2022 at 1:07 PM
    afret
    North Idaho
    Since you're 1.5" higher in the front now, why not take out the 1.5" spacer in the back? That should get you level.
  7. Jan 19, 2022 at 1:09 PM
    ToyotaRDie
    I'd like to be level but still have a bit more clearance in the back.
  8. Jan 19, 2022 at 1:55 PM
    I just measured. Front is at 37, and rear is at 38.5 average (38.25 & 38.75). I have 285's, so that adds about 1/2" over the stock tires.
  9. Jan 19, 2022 at 2:59 PM
    ToyotaRDie
    Thank you! BTW I also just installed the Black Rhino stadiums that you have. They are awesome!
  10. Jan 19, 2022 at 3:59 PM
    Nice!! I love them!
  11. Jan 19, 2022 at 5:48 PM
    Natty22
    Natty22 New Member
    Casey
    16 Silver 4RUNNER
    Working on it
  12. Jan 19, 2022 at 5:53 PM
    Are you lifting the rear?
    1.75 will be close to level if you keep the rear at regular height.
    Replacing the springs should provide the best performance.
    Welcome to the forum!!
  13. Jan 19, 2022 at 6:05 PM
    Natty22
    Natty22 New Member
    Casey
    16 Silver 4RUNNER
    Working on it
    Yes I selected the Bilstein 36-821824 springs 1.5” 4wd
  14. Jan 19, 2022 at 6:09 PM
    Natty22
    Natty22 New Member
    Casey
    16 Silver 4RUNNER
    Working on it
    Which UCA’s did you go with? Probably place a order for some JBA tomorrow
  15. Jan 19, 2022 at 6:21 PM
    I have the heavy load version of those. If you go with the 2.5" rear setting, you'll still have a subtle rake.
    I went with BDS. JBA are supposed to be nice, too.
  16. Jan 20, 2022 at 11:47 AM
    ToyotaRDie
    Would anyone know if I set the front 2.75 inches, would I need UCA’s? I know for 3 inch lift they recommend it.
  17. Jan 20, 2022 at 1:29 PM
    619T4R
    619T4R New Member
    2021 SR5P
    Here’s another option for you. I have 5100s on all 4 corners with ome 885 in front 895 in rear. I also went with element uca.
    I have a little bit of rake still. When I measured on flat ground I was at 38 front and 39 rear.
  18. Jan 20, 2022 at 4:59 PM
    Natty22
    Natty22 New Member
    Casey
    16 Silver 4RUNNER
    Working on it
    I just ordered some Eibach front springs E30-82-071-01-20, 2.75” and the JBA uca.
