4x4 shifter started vibrating heavily in idle
Discussion in '3rd Gen 4Runners (1996-2002)' started by Iacopo, Jan 23, 2025.
  1. Jan 23, 2025 at 2:13 AM
    Iacopo
    Iacopo [OP] New Member
    Iacopo
    1996 Toyota 4Runner KZN185
    Guys the 4x4 shifter of my 1996 3rd gen KZN185 auto has started vibrating a lot lately while in idle (not while driving like I’ve seen in other posts).
    I would really appreciate if someone could help me troubleshoot the issue as I can’t afford take it to the shop at the moment..
  2. Jan 23, 2025 at 7:45 AM
    Automatic or Manual transmission?
  3. Jan 23, 2025 at 10:24 AM
    Iacopo
    Iacopo
    @negusm it’s auto - thanks for getting back!
  4. Jan 23, 2025 at 10:34 AM
    If you put it in park, does it smooth out?
    If it does, I think that may be a combination of things. Your engine is probably shaking a bit more with age at lower RPMs, the Torque Converter getting worn out with age, your motor mounts are not as stiff as they were. Older automatic cars tend to vibrate while in Drive at idle and I'm pretty sure it's mostly a worn TC.
    Mine does it a bit, but it is minor. I believe it is more noticeable with the 4x4 selector since it is bolted more directly to the drive train. The automatic shifter has more linkage to take out the vibration.
