4x4 not working
Discussion in '4th Gen 4Runners (2003-2009)' started by Sejhorv8, Mar 20, 2020.
  1. Mar 20, 2020 at 10:05 AM
    Sejhorv8
    Sejhorv8 [OP] New Member
    Joe
    2005 5Runner SR5 4.0L
    Looking for so help. I has a drainage issue with my A/C condensation which caused all the water to leak under my dash. This caused my Transfer case control module to get soaked. my four wheel low light cam on and started to beep though i wasn’t in 4lo. I’ve tried a new control module with the same results.
    What else could it be?
  2. Apr 16, 2020 at 3:34 PM
    wnelax04sr5
    wnelax04sr5 New Member
    Ethan
    CT
    2004 SR5 4X4 Galactic Gray
    is there a relay related to the 4x4 system? i imagine when it was wet if actuated it may have overloaded the relay and/or blown a fuse
  3. Apr 18, 2020 at 8:45 AM
    Libagui
    Libagui New Member
    Librado
    2006 Silver 4runner limited.
    Sometimes coincidence just happen. You will have to make a full diagnostic. First check the ADD, and after the transfer case.
