4wd shifting problems
Discussion in '3rd Gen 4Runners (1996-2002)' started by 4R4hunting, Feb 7, 2016.
  1. Feb 7, 2016 at 9:22 AM
    4R4hunting
    4R4hunting [OP] New Member
    2002 4Runner Limited
    2" lift, custom bumper, Bilstein shocks
    2002 4Runner 4x4 Limited. Dash light center orange dot flashing and the 4wd will not disengage. I've tried backing up, and pushing the button on the transfer shifter in different modes. Seems like the solenoid is stuck. Any insights?
  2. Mar 3, 2016 at 1:15 AM
    Insomnia9335
    Insomnia9335 New Member
    Ryan
    Silver 3rd Gen 300,400mi
    Have you tried resetting your computer? You can reset it by disconnecting the positive terminal on your battery for about a minute. Then reconnect and see if that helps. Sometimes the wires in that system get old and it can cause a short. I've had solenoid problems in the past and they can cause issues like this. But upon a little light reading it sounds like your transfer case is binding. Do you have a button for 4WD, or do you have a manual shift lever?
  3. Mar 3, 2016 at 2:58 PM
    T-Rex266
    T-Rex266 Moderator Staff Member
    Could be your actuator too. You can try cleaning it up to see if it'll engage, but might need to be replaced.
    Insomnia9335 likes this.
  4. Mar 3, 2016 at 3:10 PM
    Insomnia9335
    Ryan
    Well with the actuator as well, you can disconnect the switch and see if there is any continuity in the switch terminals with a voltmeter. When you switch 4WD to on, remove the switch and check for continuity. If there is no continuity, then the switch is bad, replace it.
    T-Rex266[QUOTED] likes this.
  5. Mar 3, 2016 at 3:15 PM
    Insomnia9335
    Ryan
    The only way to properly check your actuator is to unplug the actuator electrical connector and check the the resistance between the terminals. It's a process and would be difficult for me to describe it, but there's a breakdown in the Haynes manual showing you how to check all that.
