4WD FLASHING RED & Solid Gr Together
Discussion in '5th Gen 4Runners (2010-2024)' started by nnobby45, Nov 3, 2024.
  1. Nov 3, 2024 at 1:52 AM
    nnobby45
    nnobby45 [OP] New Member
    Nolan
    2019 White TRD Off Rd Prem
    2019 Off Rd Prem 4R
    I have a blinking red 4WD svc light (constantly) & when going to 4WD I get the green light indicating 4 WD locked in. Tested & 4WD is engaged. Called Toyota to set up appoint. Interesting that when switching to 4WD while stopped, green light comes on instantly & goes off just as fast when disengaged. I do remember going through MUD the day before red light came on & after research am wondering if clogged tube could be the problem or if they'd even be related. Opinions appreciated.
  2. Nov 3, 2024 at 2:50 AM
    Ungood $$$
    Thacrow likes this.
  3. Nov 3, 2024 at 5:16 AM
    ADV4RNR
    ADV4RNR New Member
    Bob
    2019 Off-Road Premium
    typical lift, tires, skid plates and rock sliders
    Check to see if your rear locker button is pushed....
    If it gets pushed without the transfer case being in 4 lo, you get a flashing warning (although, I don't remember exactly what flashes)
  4. Nov 3, 2024 at 6:30 AM
    nnobby45
    Nolan
    ADV 4NR
    Many thanks! That cleared it My garage door opener buttons/interior light are just above it & I must have pushed it accidentally fumbling around in my garage in the dark. It had to have been in 2H when it happened. As mentioned, both 4H& 4L both worked while red light flashed. I had no way of knowing it was locker related. Thanks, again. - Nolan
  5. Nov 3, 2024 at 6:32 AM
    Back to good. No $$$ involved, it turns out. :)
  6. Nov 3, 2024 at 7:42 AM
    5thToy
    5thToy New Member
    Northern Nevada
    2019 SR5P
    Always a good day when there is a simple explanation to a potentially expensive problem.
    Great community!
    Saker, Imdav2u, Spare Parts and 2 others like this.
  7. Nov 3, 2024 at 10:12 AM
    ADV4RNR
    ADV4RNR New Member
    Bob
    Same thing happened to me recently.... that's how I knew to check.
    Saker likes this.
  8. Nov 3, 2024 at 1:23 PM
    Excellent outcome!
