4Runner with 295/7017 tires
Discussion in '5th Gen 4Runners (2010-2024)' started by maiyac28, Jan 9, 2026.
  1. Jan 9, 2026 at 2:48 PM
    maiyac28
    maiyac28 [OP] New Member
    casta10
    2019 4Runner
    IMG_2058.jpg I have a 2wd 4Runner running a 3inch lift with 33s and no rubbing. Is anyone running 34s and rubbing? Also curious about mpg. Thanks!
  2. Jan 9, 2026 at 2:53 PM
    34's are for wimps. Getcha some 40's!
  3. Jan 9, 2026 at 3:27 PM
    Gman2530
    Gman2530 New Member
    2018 SR5 4wd 4Runner
    The loco strikes again. Good one! :violent::headbang:
    Borracho Loco and Rocket-67 like this.
  4. Jan 9, 2026 at 4:24 PM
    2ndGen22re
    CR
    Carson Valley, NV
    1990 22RE & 22 AG ORP KDSS
    One-at-this-price stripper. Bought new 36 yrs ago, a $13K leftover. Added Detroit TruTrac, 1”rear spring spacer and “pinstripes”… Factory AC kit and roof rack bought at dealer cost at time of purchase, still blows ice cold 36yrs later. 2022 AG ORP all stock.
    How are ‘U’ turns?
    2Toys likes this.
  5. Jan 9, 2026 at 6:00 PM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS extended travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Diode Dynamics XPR reverse bulbs LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Your AI sucks.
    Grok:
    lol.
    My actual rig on 34s:
  6. Jan 9, 2026 at 7:47 PM
    Touche', sir...
  7. Jan 9, 2026 at 9:07 PM
    1SilverRunner
    Tejas
    lol. I’m actually upset that Groks viper cut looks way better than my actual viper cut lmfao.
    OP this shenanigans aside 34s fit with relative ease. I’m running 285/75/17 (skinny 34s) but 295/70/17 (33.5”) will also fit. Plenty of rigs on this forum using them.
    You’ll likely need a body mount chop and some minor trimming to the front bumper. Keep in mind offset has a rig role to play here. Negative offset = way more trimming.
    Expect <18 mpg. Expect the rig to be slower. Being RWD I honestly wouldn’t recommend going bigger than 33. Only reason to go bigger would be off-road capability.
    If this thread dies, there are plenty of other discussing it.
    Use google to find them.
    Site:4Runners.com/ 295/70/17
    ChessGuy likes this.
  8. Jan 14, 2026 at 9:30 AM
    CementTruck
    CementTruck New Member
    Neil
    2017 4Runner TRD Pro
    I ran 295/70/17 Nitto Ridge Grappler E and it did take work to get them to fit with zero rubbing. For my 4Runner, I had them mounted to 17x9 -38 wheels, which gave a ton of inboard clearance. My guess is -10 would suffice for the wider 295 tire. I have a high clearance bumper, so I'm not sure how much fender trimming would be required, and I also have BMC which is likely necessary for full articulation. Additionally, the tires would hit the painted fender flares on hard bottom-outs, but that was mostly fixed with a better bump stop. MPG was around 15-17.
  9. Jan 14, 2026 at 9:32 AM
    CementTruck
    Neil
    I'm running the same size now and imo they're the perfect size tire that blends better ground clearance, wheel well clearance, daily road performance, and off-road performance.
  10. Jan 19, 2026 at 11:27 AM
    Ksny15
    Ksny15 New Member
    Mesa, AZ
    23 TRD Off-Road
    If a 285/70/17 fits perfectly with zero rubbing I would assume a 285/75/17 would as well as they are just taller right?
  11. Jan 19, 2026 at 11:31 AM
    CementTruck
    Neil
    Taller, yes, but could be subject to contacting the body mount or fenders, depending on how much clearance you had with the 285/70. If you previously cleared with a half inch to go, for example, then the 285/75 would likely contact in that same spot since it's about .5" closer now (if you consider the overall 1" taller height). You'd also have to consider how much clearance you had at full tuck because the taller tire could now potentially hit the top or rear of the inner fender on hard bottom-outs. The latter is fixable with better bump stops.
  12. Jan 19, 2026 at 11:34 AM
    Ksny15
    Ksny15 New Member
    Mesa, AZ
    23 TRD Off-Road
    That rules out me out lol! That sucks the extra ground clearance would have been great!
    CementTruck[QUOTED] likes this.
  13. Jan 20, 2026 at 6:00 AM
    1SilverRunner
    Tejas
    My group calls them baby 35's lol.
    A 285/75/17 from most brands is a true 34" tire.
    Most 35's are only 34.4-34.6" tall.
    So the sidewall height difference is almost negligible. But, a 35x12.5 will be significantly wider so you'll have a larger contact patch. Better flotation in sand and snow.
    An aggressive body mount chop can clear 34s or 35s all day.
    I've posted about this size multiple times in other threads. Honestly it's a bit slept on. Super common size. Less rolling resistance, a little lighter, a little easier to fit than a thick 35. Makes more sense than a 295/70/17 if you're specifically looking for ground clearance.
    I've been rocking these 285/75/17 Falkens on stock gears for a couple years and the rig doesn't seem to care. Still, I'm going to regear for the crawl ratio and move to a 35 that is more capable in the mud and rocks (eyeing the baja boss AT)
    Ksny15[QUOTED] likes this.
  14. Jan 20, 2026 at 9:25 AM
    Ksny15
    Ksny15 New Member
    Mesa, AZ
    23 TRD Off-Road
    I would be all over them if it wasn't for the damn BMC! Being in AZ with mostly rock the ground clearance means so much more to me than having a thicker tire for sure. Ah maybe one of these days I will stop being a punk and just do the BMC but I need to learn a bit more about them haha. I deff love the look you have with the 34s! sometimes I think the 33s look a bit small on my 4R :sadviolin:
  15. Jan 20, 2026 at 9:33 AM
    1SilverRunner
    Tejas
  16. Feb 2, 2026 at 10:59 AM
    Ksny15
    Ksny15 New Member
    Mesa, AZ
    23 TRD Off-Road
    Sooo this stupid thread has been looking into 285/75/17s and just having the BMC done lol. These damn tires weigh a ton though. Does anyone have any experience with the Milestar Patagonia A/T Pro? On the Jeep forms they actually seem to be pretty well regarded. What I like about them is in 285/75/17 they weigh less than 50 pounds which is wild.
  17. Feb 2, 2026 at 11:17 AM
    2020 Venture / 2017 Tacoma
    And they are cheaper on top of that. Something is odd though. There are a few members using them. Check it out in the search function with the tire name and you will see it.
  18. Feb 2, 2026 at 1:47 PM
    hossler1788
    hossler1788 DADWAGON
    Joshua
    Central Pa
    2020 4runner
    I do
    Had them for a little while now. They are a great tire. Only flaw to me, is they are on the louder side of a/t tires. But the are fantastic in the rain and snow. Yes they are light weight compared to everything else. Still expect to take a hit mpg wise and i highly recommend getting a ott tune when going to this size.
  19. Feb 2, 2026 at 4:44 PM
    Ksny15
    Ksny15 New Member
    Mesa, AZ
    23 TRD Off-Road
    Thanks for the reply, They are actually 5 pounds less than the Cooper Evo's I'm running now which is pretty wild. Noise doesn't bother me to much. I've read a few people having sidewall issues but it seems like the overwhelming majority seem to like the tires.
