4Runner Stalking, er...um, SPOTTING with Charlie™ (6th Gen Edition)
Discussion in '6th Gen 4Runners (2025+)' started by PennSilverTaco, Feb 27, 2025.
  1. Sep 23, 2025 at 6:24 PM
    PennSilverTaco
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck
    Please see signature!
    September 21st, 2025:
    Bethlehem, Pennsylvania
  2. Sep 24, 2025 at 10:52 AM
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    2025 TRD PRO
    September 22nd, 2025:
    Pipersville, Pennsylvania
  3. Sep 24, 2025 at 5:00 PM
    Archer
    Archer New Member
    2025 Ice Cap 4 Runner TRD Pro
    Hamburg, Pa. lol
  4. Oct 1, 2025 at 6:13 PM
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    It would appear that somebody traded one in…
    September 28th, 2025:
    Doylestown, Pennsylvania
    IMG_5021.jpg IMG_5022.jpg IMG_5023.jpg IMG_5024.jpg IMG_5025.jpg IMG_5026.jpg
  5. Oct 2, 2025 at 5:01 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    it’s ight
  6. Oct 26, 2025 at 10:51 AM
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    2025 TRD Off-Road
    October 25th, 2025:
  7. Feb 5, 2026 at 7:25 PM
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    2026 TRD PRO
    February 5th, 2026:
    Philadelphia, Pennsylvania
  8. Feb 11, 2026 at 11:29 AM
    semprenissart
    semprenissart Mèfi
    2022 4Runner TRD Pro (MGM)
    did they remove the fine airflow fan adjustment in the 6th gen?
  9. Feb 23, 2026 at 7:47 PM
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    :notsure:
  10. Feb 23, 2026 at 7:49 PM
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    2026 Limited
    February 22nd, 2026:
  11. Feb 23, 2026 at 9:44 PM
    Couldn't quite zoom in enough, but it looks like I saw a final price of $71,900.00 ish...
  12. Feb 25, 2026 at 10:16 AM
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    Wouldn’t shock me!
  13. Feb 25, 2026 at 10:28 AM
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    2025 SR5
    February 25th, 2026:
  14. Mar 2, 2026 at 11:30 AM
    22 ORP
    Aftermarket wheels with 2 inches of poke. Aaaaand:
    Raptor lights.
  15. Mar 2, 2026 at 4:14 PM
    2Toys
    2Toys Imperial Star Cruiser
    Gordon
    2019 4Runner TRDORP
    :puke:
    Just my opinion, of course.
  16. Mar 2, 2026 at 5:38 PM
    22 ORP
    Yup. The term “clown show” comes to mind. Although I must add that I don’t share the common revulsion for Raptor lights and widdle wadders.
    2Toys[QUOTED] likes this.
  17. Mar 2, 2026 at 5:55 PM
    2Toys
    Gordon
    2019 4Runner TRDORP
    The double mustache front end (I do like the headlights), the fugly wheel wells (Was there a competition to see who could design the worst looking? Maybe alcohol or illicit drugs involved?) and then there's the taillights...
  18. Mar 21, 2026 at 6:45 PM
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    March 21st, 2026:
  19. Apr 22, 2026 at 6:20 PM
    #49
    PennSilverTaco
    Charlie
    2010 Zombie Truck
    April 22nd, 2026:
