4Runner recovery points
Discussion in 'General 4Runner Talk' started by Commited, Mar 18, 2022.
  1. Mar 18, 2022 at 9:16 AM
    Commited
    Commited [OP] New Member
    Oscar
    So Cal
    2019 Silver Metallic TRD ORP
    Tinted fronts, blacked out overlays.
    Hello all. Are the 2 tie-down points at the front of the 4runner considered recovery points or are those used for tie-downs when the vehicle was transported overseas?
    The last breed likes this.
  2. Mar 18, 2022 at 10:01 AM
    They are tie downs for transporting, but several members have used them for recovery with no problems.
    The last breed and Commited[OP] like this.
  3. Mar 18, 2022 at 1:04 PM
    Commited
    Oscar
    So Cal
    Thank you!
  4. Mar 18, 2022 at 6:34 PM
    Beachguy
    2024 TRP ORP
  5. Mar 19, 2022 at 2:27 PM
    They are mentioned in the manual as suitable for towing on flat surfaces for a limited distance.
    if you use them for recovery situations, use caution.
    polyguy79 likes this.
  6. Mar 20, 2022 at 9:20 PM
    polyguy79
    polyguy79 New Member
    LA County
    2021 White Runner ORP
    RCI aluminum skids (front, trans, TC, and gas), RCI steel sliders 20 degree no plates with kickout, Treaty Oak recovery points, LFD stainless crossbars, Greenlane ladder, Toyo Open Country AT III, Bilstein 5100s, OME (front 2” lift) and Eibach (rear 1”lift) coils
    If you used a bridle for both points and needed a minor tow out of a tough spot, you are probably OK. If you are stuck on something good or deep in mud and need a more of a jerk recovery, I wouldn’t trust them too much. You will probably be OK if this was a one off, but you are taking a chance.
    Ripper238 likes this.
  7. Mar 20, 2022 at 9:24 PM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    Why does this question keep getting easier recently?
    use them. You’re fine.
    DRobs, donnermel and SlvrSlug like this.
  8. Jun 5, 2023 at 11:27 AM
  9. Jun 5, 2023 at 11:49 AM
    Did anybody search about this AFE option? Seems like they bolt on directly to sway bar location. But so far I only see Tundra using it, none for 4Runner even though its in the 4Runner product list. Install seems to be much easier than other options. But by the looks they don't look that strong.
  10. Jun 5, 2023 at 12:20 PM
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    So basically there are no front recovery points.
    djwantke likes this.
  11. Jun 8, 2023 at 2:52 PM
    The sway bar bracket bolts are too small. These are likely weaker than the factory welded hoop on the front crossmember.
  12. Jun 8, 2023 at 4:20 PM
    I see.. Thanks for that info. Little surprising though for a known company like AFE Power having a product published as "Dedicated recovery points" that are not safe for recovery.
  13. Dec 2, 2023 at 10:51 AM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    CAN ANYONE TELL ME THE CRUSH BAR BOLTS TORQUE!?
    thx
