4runner lift question with KDSS
Discussion in 'Suspension' started by 4runnerx4, Oct 26, 2020.
  1. Oct 26, 2020 at 8:04 PM
    4runnerx4
    4runnerx4 [OP] New Member
    Josh
    2015 4runner Limited 4WD XREAS
    4 inch lift Retrofit headlights Tint Wheels Tires 33x12.50
    Hello all I’m new to this forum sry if this exact question has been asked but I really want a bigger lift as well as upgrades struts with coil overs but I don’t know where to go or what to get I have a limited but I am switching to a Trail bumper with the trd pro grille swap due to my bumper warping from and old shop as well as more clearance. I’m wanting a 6 inch lift no body lift or anything dumb, I mainly just use my runner to commute and occasionally go off-roading on my land or camping so nothing hard core. Just can’t seem to find what I need to get for a 6 inch with the KDSS anything helps thanks!
  2. Oct 26, 2020 at 8:27 PM
    Limiteds don't have KDSS...they have XREAS.
    4runnerx4[OP] likes this.
  3. Oct 26, 2020 at 9:03 PM
    Mtbpsych
    Mtbpsych New Member
    A 6 inch lift on a 4runner is dumb, IMO.
    I suggest doing a little more research into suspension.
    Check this out, it’s for a tacoma, but still applies to the 4runner.
    https://youtu.be/QKXj0jBenIk
  4. Oct 28, 2020 at 1:14 PM
    4runnerx4
    Josh
    I thought that was only on the 4th gen Limited’s are you sure it is on the 5th gens too? After doing my 4inch lift for a KDSS I’m pretty sure I have KDSS but maybe I’m wrong
  5. Oct 28, 2020 at 1:14 PM
    4runnerx4
    Josh
    Posted my reply. I don’trlly know how this forum works sry
  6. Oct 28, 2020 at 1:36 PM
    If your front swaybar doesn't attach to the front lower control arms like this:
    Or doesn't look like this with the hydraulic cylinder in the circle:
    You don't have KDSS.
    KDSS was never offered on Limited 4Rs.
  7. Oct 28, 2020 at 3:04 PM
    Dillusion New Member
    KYle
    If you got a Limited its not KDSS you got XREAS and from your avatar you have a Limited.
    Only way to get 6" is with a kit I believe is with a Crossmember (or whatever they call it now Bracket...) lift. I'm sure someone has done it on a Limited but few and far between.
