4Runner Lifestyle Stealth taillight problem
Discussion in '5th Gen 4Runners (2010-2024)' started by speedevil, Jun 18, 2025 at 7:25 AM.
  1. Jun 18, 2025 at 7:25 AM
    speedevil
    speedevil [OP] New Member
    Dale
    2015 4runner
    These lights were installed when I bought my 2015 SR5, and the seller included the original lights. The problem is that the reverse lights do not work, on either side. I've checked the BKP fuse (10a) and it's good.
    Any suggestions on how to resolve this problem?
    Thanks in advance.
  2. Jun 18, 2025 at 7:51 AM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    Re-install the originals. See if the lights come on, then you'll know if it's a light problem or a wiring problem.
    Rocko9999 likes this.
  3. Jun 18, 2025 at 7:53 AM
    Possibly dead bulbs.
  4. Jun 18, 2025 at 7:55 AM
    catbrown357
    Tempe
    2011 Limited 4WD
    I'm assuming these aftermarkets are LED? That's why I didn't go there. But I know nothing about them. Nor do I care to research.
  5. Jun 18, 2025 at 8:08 AM
    Yeah not sure myself and also not a fan of most aftermarket tails. They all want to be a Ford.
    catbrown357[QUOTED] likes this.
  6. Jun 18, 2025 at 8:33 AM
    Does your backup camera work? The transmission position indicates "R" in the gauge cluster when you selected reverse? Just want to rule out a bad transmission range sensor aka neutral safety switch.
    Slopemaster likes this.
  7. Jun 18, 2025 at 8:36 AM
    speedevil
    Dale
    2015 4runner
    Backup camera works and the main dash says "R". So the switch on the transmission appears to be working.
    I'll unplug the existing lights and plug in the originals and see if I have reverse lights then. If I do I'll just put the original lights back in.
  8. Jun 18, 2025 at 8:39 AM
    catbrown357
    Tempe
    2011 Limited 4WD
    Let us know what you find.
  9. Jun 18, 2025 at 9:06 AM
    speedevil
    Dale
    2015 4runner
    I unplugged the aftermarket lights and plugged in the originals, and I have reverse lights. The aftermarket lights are in a box in the barn and the originals are reinstalled. Problem solved.
  10. Jun 18, 2025 at 11:46 AM
    Those backup bulbs are replaceable on OEM assemblies. I wonder if the aftermarket assemblies have replaceable or soldered in LED modules.
  11. Jun 18, 2025 at 12:02 PM
    I felt the same until I found these Unique Style Racing assemblies. Looks like OEM with a lot of the chrome blacked out.
  12. Jun 18, 2025 at 12:53 PM
    I run those. Their turn signals and reverse lights lasted maybe a year so I went with VLED replacements.
    Saker[QUOTED] likes this.
