4runner help!
Discussion in '4th Gen 4Runners (2003-2009)' started by Thevault301, Apr 12, 2019.
  1. Apr 12, 2019 at 5:52 PM
    Thevault301
    Thevault301 [OP] New Member
    Joshua
    Appomattox Virginia
    2006 Sr5 All-4WD V8 4Runner
    None all stock
    Help! My Check engine light,VSC TRAC,And slip indicator came on! All I did was Refuel it. Its struggling to get up to speed even with the pedel to the floor only gaining 5 Every 10 or 20 seconds
  2. Apr 12, 2019 at 7:57 PM
    HoBoDanny
    HoBoDanny Dude...
    Daniel
    Kentucky
    2004 SR5 V6 4WD 4Runner
    Check your fuel cap make sure it’s tightened for a few clicks.
  3. Apr 12, 2019 at 8:58 PM
    ^this- try this first
    It sounds like the truck is running in "limp" mode. That happened to my '03 once when I hit a slush puddle. It was like the ECU had a brain fart. It accelerated slowly and wouldn't down-shift.
    If this sounds like your issue, and the gas cap wasn't the problem, try resetting the ECU. You can reset the ECU by disconnecting the battery for about 30 minutes. This will clear the codes or whatever is causing it to act up.
    If the problem comes back, there's probably something else wrong.
    Good luck! Let us know what you find out
  4. Apr 12, 2019 at 9:22 PM
    4Runner fun
    Ryan
    Nebraska
    I have 2 options.
    1. Fuse - happened so suddenly.
    2. Fuel filter - coming with diesels I know the importance. If you got water in your tank... Did it rain recently?
    Hope you get home.
    Sorry, new to Toyota...
  5. Apr 13, 2019 at 11:08 AM
    Thevault301
    Joshua
    Appomattox Virginia
    None all stock
    Update: I got the 4runner Scanned and it came back as a bad fuel air enjecter the secondary one
  6. Apr 13, 2019 at 11:18 AM
    Did you get it fixed? Sounds expensive
  7. Apr 13, 2019 at 12:02 PM
    Thevault301
    Joshua
    Appomattox Virginia
    None all stock
    No I'm gonna have to drive my secondary Vehicle until my friend has time to install the part. It Sucks how he has to take the whole entire Top part of the engine apart though.
  8. Apr 13, 2019 at 1:05 PM
    Yeah, sounds like a project. At least you won't have to pay a mechanic.
