4runner Abs Control system
Discussion in '4th Gen 4Runners (2003-2009)' started by Thevault301, Jun 17, 2019.
  1. Jun 17, 2019 at 10:00 AM
    Thevault301
    Thevault301 [OP] New Member
    Joshua
    Appomattox Virginia
    2006 Sr5 All-4WD V8 4Runner
    None all stock
    Okay. Long story short check engine light came on. I took it to toyota dealership and preformed a System scan. The following codes came back. C1223 C1241 C1253. They summerized it all up and said it all is going to cost 1500 to fix all of this. Should i allow the dealership to fix this or can i do it myself. I really dont wanna have to pay 1500 for them to fix it.
  2. Jun 17, 2019 at 5:45 PM
    chassis
    chassis New Member
    Indiana
    Sold: 2005 4Runner SR5 V6 4WD
    Google found these things:
    C1223 Brake light switch
    C1241 Low battery voltage
    C1253 ABS inlet valve coil LR circuit short to ground
    Try replacing the brake light switch, $15, 10 minute job. See if the codes clear.
    If still codes, remove the battery positive cable and touch it to the negative post, then wait 5 minutes. Reconnect the positive cable and see if the codes clear.
    If still codes, buy a new battery. See if the codes clear.
    While you're at it, for good measure, be sure your gas cap is tight - three clicks.
  3. Jun 17, 2019 at 6:10 PM
