4RUNNER 2016 limited brakes by itself
Discussion in '5th Gen 4Runners (2010-2024)' started by oskiev85, Sep 26, 2024.
  1. Sep 26, 2024 at 9:55 AM
    oskiev85
    oskiev85 [OP] New Member
    4runner 2016 limited
    Hello everyone, I have a very strange problem with my 4Runner. It brakes by itself, a light on the dashboard turns on, it makes a noise like the ABS, and it brakes without pressing the brake pedal. My mechanic doesn't know what to do, and I have the computer plugged in but it doesn't detect the fault in the history. I am sharing a video where I explain it, but it's in Spanish. Does anyone know what it could be?
    Imdav2u likes this.
  2. Sep 26, 2024 at 10:04 AM
    Emmantik
    Emmantik New Member
    Coquitlam, British Columbia
    2015 Magnetic Grey SR5P
  3. Sep 26, 2024 at 12:53 PM
    Your scanner needs to be able to read brake system codes, which are not engine codes and therefore not stored in the ECM. That'll be the first step in the diagnosis.
    If your scanner has real time data, you can jack the vehicle off the ground with the transmission in neutral. Spin each tire by hand and verify the wheel speed data in the scanner shows sensible values with no dropout.
    Technologic80, Shredder and 5thToy like this.
  4. Oct 1, 2024 at 11:00 AM
    oskiev85
    thanks, guys i will let you know what happens we tried everything and all check out ok !
  5. Oct 1, 2024 at 11:14 AM
    Technologic80
    Technologic80 Sexy Member
    Chris
    SE Michigan
    '23 TRD Off Road Premium
    Find a new mechanic.
    Pentangler likes this.
  6. Oct 1, 2024 at 10:40 PM
    Beside a bad wheel speed sensor, it’s possible that you need to do a zero point calibration. Sometime after an alignment where they adjust steering wheel center will cause the zero point to need resetting.
