4runner 2004 lifted- control arms problems
Discussion in '4th Gen 4Runners (2003-2009)' started by Omer, Nov 1, 2020.
  1. Nov 1, 2020 at 8:31 AM
    Omer
    Omer [OP] New Member
    Omer
    4runner 2004 v8 limited
    Hello,
    Few months ago I installed the daystar kit (2.5/1.5), then changed my tires to 265/70 (which applied additional minor lift).
    Since then, my front suspension making some ugly noises (like metal touching metal). Especially over bad roads and bumpers.
    Took my vehicle to some shop and they recommended to replace front control arm and bushing. I'm living in Guatemala so not trust the shops here in 100%..
    From your understanding, this kind of lifting is affecting the lower or upper front control arms? The front bushings are going pair for lower / upper?
    Please, I'll appreciate some information so I can take care this issue. The front wheels are out of balance, the new tires are worn in a bad way and these metal noises makes me leave my windows close all time so I will not hear the ugly sound.
    Thanks experts!
  2. Nov 1, 2020 at 8:33 AM
    Antman
    Antman New Member
    Anthony
    Post some pictures of the control arms please.
  3. Nov 1, 2020 at 8:55 AM
    81runner
    81runner New Member
    SoCal, Ventura County
    2007 4runner, modified...
    If I had to guess, the noise is most likely the sway bar hitting the coil over since you didn't list as having done, but 4th gens need a sway bar relocation relocation to lift.
  4. Nov 1, 2020 at 12:52 PM
    Omer
    Omer
  5. Nov 3, 2020 at 9:23 PM
    Omer
    Omer
  6. Nov 4, 2020 at 5:29 AM
    Antman
    Antman New Member
    Anthony
    you need better pictures. You can’t see the UCA’s or the sway bar in this picture. Or a clear shot of the shock and sway bar.
  7. Nov 4, 2020 at 8:49 AM
    CowboyTaco
    CowboyTaco New Member
    Michael
    2011 Tacoma DCSB
    x2 on better pictures.
    I assume you had to lower the LCA to install the daystar. If so, make sure the LCA is torqued down properly. This seems to cause a metal-to-metal clunk sound.
    As others said, check to see if the sway bar is contacting. A relocate kit is cheap and will eliminate that as a possibility, but if you didn't get larger springs, it seems unlikely to me that this is the issue.
    If you do replace the UCA, look into one of the aftermarket options (like JBA or SPC). If you go with an OEM style replacement, stay away from Dorman. I've regretted that decision on my own truck for far too long.
    81runner likes this.
  8. Nov 7, 2020 at 7:38 AM
    WarChild
    WarChild New Member
    2005 JRU 4Runner
    you don't have lift either. ou have just a bit more ground clearance though.
