4low blinking light/tight shifting/Cruise control wont set
Discussion in '5th Gen 4Runners (2010-2024)' started by Estyanne, Feb 11, 2023.
  1. Feb 11, 2023 at 8:03 AM
    Estyanne
    Estyanne [OP] New Member
    Anne
    2017 White 4Runner SR5 Premium
    leveling with bilstein shocks, front and rear....just beginning the process
    Hola my Runner peeps! Question. I was out running errands this morning and all of a sudden my 4low started blinking. I haven't used 4h in while and have been driving with no issues. Having said that, when i shift into gear, its been tight. I thought I was imaging things..but nope. Also, cruise control will turn on but not set. I'm assuming its because if the 4l blinking light. Any thoughts? Was good on my first leg out this morning...just on the return it started.
    Thanks for any insight!
    Anne
  2. Feb 11, 2023 at 10:24 AM
    Try shifting into low range and back out. Ultimately a proper scanner than can talk to the 4WD computer is needed to see what code is being thrown. A regular scanner won’t do it.
  3. Feb 11, 2023 at 1:14 PM
    Old goat
    Old goat Trout chaser
    Hudson Valley NY
    5th gen
    Same issue with my 2015… was the neutral safety switch. I sprayed PB blaster on it a few days apart, it’s been fine since
  4. Feb 11, 2023 at 1:45 PM
    mrmike7189
    mrmike7189 New Member
    mike
    2020 silver SR5 4x4
    Neutral safety switch. In a few more miles of driving, your check engine &"See toyota dealer " will light up on your dash. Seems to be an issue lately. It happened to mine at 33k miles. was covered under warranty.
