4 lo light, traction & engine lights Blinking
Discussion in '5th Gen 4Runners (2010-2024)' started by lisawiththevizsla, Dec 31, 2024.
  1. Dec 31, 2024 at 6:48 AM
    lisawiththevizsla
    lisawiththevizsla [OP] New Member
    2013 Limited 4 Runner
    Help! I started my vehicle this morning & 4lo light ,traction & check engine lights all blinking. Honestly I haven't ever engaged the 4 lo. So I tried everything in my manual to disengage. To H4 I drove it & doesn't feel right. Any suggestions as to why? I just drove it the other day & it was fine.
  2. Dec 31, 2024 at 7:04 AM
    Sounds like the electronic transfer case actuator is the culprit. If the actuator never gets used, it can cause problems. The wife’s Sequoia has the same issue because she doesn’t exercise 4H/4L. We were quoted $3-4k to fix. Transfer case has to come out and be disassembled to replace actuator. It’s a use it or lose it system. This is one advantage of the manual transfer case.
  3. Dec 31, 2024 at 11:04 AM
    Hungryhawk
    Hungryhawk New Member
    Southern CA
    2017 SR5
    Try putting in 4H and move straight forward & back a couple feet max. Your driveway is fine. Then select neutral gear and put in 4 lo. My daughter 4runner also was stubborn as she never shifted into either 4WD in over 11 months.
    After several attempts the 4 H and 4 lo lights were NOT blinking. My SR 5 clunks when actuator engages 4lo.
    I have read its good to cycle the 4WD actuators every month or so.
    lisawiththevizsla[OP] likes this.
  4. Dec 31, 2024 at 11:08 AM
    Hungryhawk
    Southern CA
    2017 SR5
    Was your runner cold or did you try 4WD afer a drive in 2WD?
  5. Dec 31, 2024 at 1:07 PM
    Is the transmission shifting correctly and moving smoothly through all positions?
    If the Neutral Safety Switch (NSS) is being wonky, it can trigger a bunch of warning lights.
    Mine does it occasionally and I lose overdrive and cruise control too.
  6. Dec 31, 2024 at 1:09 PM
    OP has a Limited, which is never in 2WD.
  7. Dec 31, 2024 at 1:12 PM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    Wheel speed/abs sensor most likely broke. Had this happen to me recently.
    Google image search above and find the locations of them and check them. Or if you have a close by oreilly/advance auto that has a professional scanner it should show up appropriately.
  8. Dec 31, 2024 at 2:37 PM
    Is the check engine light blinking or solidly lit? Blinking is bad.
  9. Jan 1, 2025 at 5:50 AM
    Strongarm
    Strongarm New Member
    2023 4Runner
    I would start by using a code reader. Most parts stores will read a code for free hoping you will buy their parts. Sometimes a check engine light will illuminate with other lights to get your attention. One could only speculate your issue without knowing the code. There are a ton of different codes. Many different possibilities. When you know the code it will be easier to diagnose. Could be a loose gas cap. Maybe a misfire?? Best to read the code first.
  10. Jan 2, 2025 at 6:43 AM
    lisawiththevizsla
    Thank you all for your thoughts. Apparently a Critter made a nest in my truck & completely chewed through the wiring. So they are replacing wiring & Gaskets. Also changing the spark plugs.
  11. Jan 2, 2025 at 10:58 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Sorry for your luck! That bites. Pun intended.
    I've been using this stuff for about a year. No idea if it really works, but I spray around my engine bay every oil change. :notsure:
