4.56 gears
Discussion in '5th Gen 4Runners (2010-2024)' started by 2021venture, Jul 22, 2024.
  1. Jul 22, 2024 at 8:58 AM
    2021venture
    2021venture [OP] New Member
    Todd
    2021 Venture
    Regear has been a project I have debated since buying the truck. The cost of this is the main reason I put it off and was stuck in analysis paralysis if it would be worth it. I have completed my 500 mile break in and wanted to provide some feedback.
    Truck accelerates quicker as expected and takes less skinny pedal. Holds 5th gear and cruise control doesn't gear hunt. I am sure this won't be 100% fixed but it's greatly improved. RPM is 2600 at 75 which was the main trade off of this mod.
    Another nice change is I can increase speed with gradual throttle going uphill without dropping gear. This was not possible 3.73.
    I know this is a very subjective topic. Some people are fine with performance amd others are not. I suspect alot of it has to do with where you drive and how. I do a lot of interstate traveling and the gear hunting was killing me crosswinds or inclines.
    For reference my setup:
    2.5 " lift, low profile roof rack, RCI full aluminum skids, RSG sliders, low profile front and rear bumper, winch.
    I stayed on 265 measuring the performance impact on each mod. Now with the regear I can jump to 33 or 34 no problems. Everyone that I have talked to wished they had done this mod sooner.
  2. Jul 22, 2024 at 9:37 AM
    Agent_Outside
    Built 2011 T4R Limited
    4.88s are the best thing I’ve done to my 4Runner.
    Ironguy and 2021venture[OP] like this.
  3. Jul 22, 2024 at 9:39 AM
    2021venture
    Todd
    2021 Venture
    The upgrade I have not heard one person regret. Really improved the driveability.
    Trail Runnah and Slopemaster like this.
  4. Jul 22, 2024 at 9:47 AM
    Acesandeights
    Acesandeights #34
    2024 ORP
    Depends on the question, but a 22.5% increase in torque is the objective answer ;) . If you don't need more torque, then it's not cost-effective, but for me, it would be great. Glad you like it. Enjoy the new-found power!
    Trail Runnah likes this.
  5. Jul 22, 2024 at 9:52 AM
    jeepster09
    jeepster09 "Old"-Member....
    Twin Cities MN
    4Runner 2008 Sport
    A work in progress.....
    Re gearing MAY even improve MPG's. I did both my Cherokee and Wrangler and it made huge difference. My Wrangler struggled in the mountains with the stock 354 gears and was very happy with 411's.
    alittleoff and Trail Runnah like this.
  6. Jul 22, 2024 at 9:57 AM
    blksubykid
    blksubykid New Member
    best upgrade to date
    jeepster09 likes this.
  7. Jul 22, 2024 at 10:17 AM
    2021venture
    Todd
    2021 Venture
    This may seem odd but I am hoping to run lower RPM after the regear. Often using 5th gear was not possible and I was in 4th screaming at high RPM. This was my realization might as well lower my gear ratio and hope to reclaim 5th as a useable gear.
    I stopped worrying about mpg in this rig. Wouldn't be driving or doing mods if fuel efficiency was my concern.
    alittleoff likes this.
  8. Jul 22, 2024 at 10:34 AM
    Acesandeights
    Acesandeights #34
    2024 ORP
    You will run at higher RPM almost always (like driving in 4st all the time), but almost never drop to 4st on the highway. At any given speed, your RPM should be 22.5% higher than it was, since you'll be driving around town in 5rd, not 4st and your gear ratio is 22.5% lower.
    You increased your RPM the same as the percentage of increase in differential/axle gear ratio, which is 22.5%. The difference between 4st and 5rd is close to 28%. You should be able to run the same speed in 5rd as you did in 4st and roughly the same RPM, meaning it should almost never drop to 4st where it did in the past on the highway in the mountains.
  9. Jul 22, 2024 at 10:35 AM
    jeepster09
    Twin Cities MN
    4Runner 2008 Sport
    I understand that. I put 456 gears in my Mustang that had 5 speed and was only turning 3200 rpm in 5th at 70 mph. I loved those gears.
    ChessGuy likes this.
  10. Jul 22, 2024 at 10:38 AM
    To clarify, Did you re gear or are still debating?
  11. Jul 22, 2024 at 10:39 AM
    2021venture
    Todd
    2021 Venture
    Re gear complete.
  12. Jul 22, 2024 at 10:49 AM
    Well done! Glad you took the leap of faith and got it done.
  13. Jul 22, 2024 at 6:14 PM
    Gears are fun!
  14. Jul 22, 2024 at 9:41 PM
    Are 4st and 5rd anything like 1th and 3nd?
  15. Jul 23, 2024 at 4:37 AM
    coachhomer
    coachhomer New Member
    I apologize for the ignorant question but what is the work required to get this done?
    thanks
    C
  16. Jul 23, 2024 at 4:39 AM
    2021venture
    Todd
    2021 Venture
  17. Jul 23, 2024 at 4:59 AM
    mcat707
    mcat707 MURDERED TRD
    NOR*CAL - Solano County
    2015 TRDPro - Attitude Black Metallic 218
    I debated getting 4.56 or 4.88, The Rear End Shop I went to recommended I go with 4.88 since my rig is lifted with 34’s, armor, Gobi rack, steel bumper, winch, etc. Now I need the speedometer calibrated. My GPS app says I’m going 4-5 mph more than what the speedometer says when going 75-80mph. I’m averaging 11-12mpgs by hand calculations, so my MPGs could be a little off.
    Yes, one of the upgrades or mods that should have been done long ago.
    2021venture[OP] likes this.
  18. Jul 23, 2024 at 5:09 AM
    2021venture
    Todd
    2021 Venture
    Is it possible to recalibrate the speedometer? On my g1 taco this could be done by replacing the speedometer gear. I didn't think on the g5 it could be recalibrated.
  19. Jul 23, 2024 at 6:43 AM
    Acesandeights
    Acesandeights #34
    2024 ORP
    It would have been a nice option from the factory, but the factory builds what they want to sell, not what buyers want to buy.
  20. Jul 23, 2024 at 6:55 AM
    2021venture
    Todd
    2021 Venture
    They used to in the 90s, some came from factory with 4.56.
  21. Jul 23, 2024 at 7:04 AM
    alittleoff
    alittleoff New Member
    Steve
    406
    '16 TP
    We had a '93 HiLux ex/cab. I chose the 3.0L V-6, 4.56 and 31" tire package.
    Standard model was 4.11 and I4.
    Those were the days...
