3rd Gen Manual Conversion Pls Help
Discussion in '3rd Gen 4Runners (1996-2002)' started by 98runner20, Dec 28, 2020.
  1. Dec 28, 2020 at 2:00 PM
    98runner20
    98runner20 [OP] New Member
    1998. 4Runner 3.4 5VZFE
    Poor Man lift (EMU), in process manual conversion, CVJ Axles, 285/75/17
    Hi, I'm new here I have a 1998 4runner and I'm doing a manual conversion. I have the clutch pedal mounted and everything is coming together nicely. My problem is pin outs to m/t computer. Have done some research and found the list of pinout for most third gens.
    So I have a ECU from a 95 1/2 4runner and a manual wiring harness from a 2002 4runner. Pickings are slim around here and it's all I could find. Is this even possible with that hardware? I don't have alot of time on my hands as I just got a job at midus full time. Does anyone know what wires are absolutely necessary to get this running? I know that some wires are different colors and go in different locations. I guess I just need to do some more research but any input would be greatly appreciated. Thanks and God Bless.
  2. Dec 28, 2020 at 2:40 PM
    98runner20
    The only manual plugs I'm missing are
    E7 Pin 8 which is E3
    E7 Pin 7 which is TE1
    E7 Pin 5 which is OX1
    E6 Pin 3 which is HT1
    E6 Pin 5 which is G-
    E6 Pin 7 which is E03
    The auto and manual 2002 4runner share the same layout of pins according to the PDF I downloaded
    The following are the wires that I have not matched to the 95 and a half plug.
    WFSE
    IGSW
    FC
    NSW
    NE+
    G2
    E1
    PSW
    TBP
    RSC
    E01
    E02
    TC
    E05
    E2G
    THA
    AF1+
    THW
    HTAF1
    PTNK
    AF1-
    So I would think 6 of these would match the above but I don't know which ones are necessary.
    Trekker likes this.
  3. Jan 1, 2021 at 5:22 PM
    Kwikvette
    Kwikvette Kwik Fab
    Multiple
    Interesting; I would've assumed the drive by wire found on later models would've posed an issue.
    Curious to see the end result. :popcorn:
  4. Jan 30, 2021 at 3:29 PM
    Vermin5
    Vermin5 New Member
    Hey man - I can't answer your question entirely, but I can tell you that theres no such thing as a 2002 manual wiring harness. I'm doing the same swap on my 02. The last manual 4Runners were made in 2000, there was no manual option in 02.
