3rd gen Engine replacement
Discussion in '3rd Gen 4Runners (1996-2002)' started by buraurio, Sep 26, 2023.
  1. Sep 26, 2023 at 10:21 AM
    buraurio
    buraurio [OP] New Member
    I just want to get a general idea of what’s out there. I’m thinking of replacing my engine, 3.4L, in my 2002 4runner. It currently has a JDM, but the milage is unknown. Nothing wrong with it, im just thinking for the future. The options i have are; rebuilt (keep same engine), JDM (milage can be off), or remanufactured (similar to rebuilt). Any thoughts or builders?
  2. Sep 26, 2023 at 12:00 PM
    If you do a compression and leak down test and everything is healthy. There is literally NO reason to even think to replace the engine.
  3. Sep 26, 2023 at 12:23 PM
    Kwikvette
    Kwikvette Kwik Fab
    Multiple
    This.
    JDM swapped engines normally have less miles than US variants they replaced (you can look up why) and even then, plenty of US models have well over 500k documented miles
    I got rid of two different 5VZ equipped vehicles with 300k miles on original engines
  4. Sep 28, 2023 at 9:25 AM
    Trekker
    Trekker Regular Member
    1997 3rz 5spd
    In this economy don’t do it unless you need it.
    However, if you are looking try getting a 1kz diesel engine. You’ll gain range and diesels are cool. It’ll be more involved.
  5. Sep 29, 2023 at 9:52 AM
    mousemeat
    mousemeat New Member
    Memphis, TN.
    1997 4 runner limited
    why replace it ? unless previous owner did hardly anything...those engines, if kept up, will run almost forever
    Trekker likes this.
